Old 10-10-2007, 02:28 PM
25ghosts 25ghosts is offline
Default Fades on Multiple Regions get Deleted after Tempo Change
Hi - I use Pro Tools version 7.3.1 CS 5 on a PPC G5 Dual 2.3 GHZ running an HD|3
Today I made an awkward discovery after having used beat detective on a stereo 2 bar drum loop. I do this rather seldom so I have not had this situation before today.
I had chopped the loop into about 16 separate hits and on about half of them I applied fades to get some tightness and sort out the non-zero crossings. I used NO x-fades.
After doing this I set the time base to ticks on the stereo audio track. The original tempo was 89 bpm. I set the tempo manually to 85 and everything sounded perfect - even at tempo 45... Now I changed the tempo in the other direction. To 98 bpm. Everything started to sound weird and : Many of the hits were only played to 50% sounding chopped off - mostly at the beginning of the hits. So I hit undo tempo change. And PT reverted to 89 bpm. My regions were now officially missing more than 60% of the fade files that I had carefully created and that even after hitting UNDO...
Now I do understand that making the tempo faster will create some overlapping - specially when the regions are lying almost perfectly close - but what I do NOT understand is why PT does NOT revert to fades after hitting undo or setting the tempo back to original 89. IMO - if I am understanding the concept right PT should NOT delete the fade files when I increase the tempo. And hitting UNDO should MOST definitely restore what was there before changing the tempo...
Any advice or comments are most welcome
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
How do I change length of multiple regions after fades are applied? jkuehlin Pro Tools 10 3 08-02-2013 06:04 PM
Fades on multiple regions. cosboud macOS 2 03-07-2012 09:49 PM
Multiple regions with fades HELP Fullsound Recording Pro Tools TDM Systems (Win) 7 10-04-2010 10:53 AM
Auto fades between multiple regions, how to? Mark 66 Pro Tools TDM Systems (Mac) 6 04-12-2004 09:54 PM
Automating A Click - TEMPO CHANGE - IS IT POSSIBLE *DELETED* IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-12-2004 02:42 PM
