Old 09-22-2007, 03:18 PM
tash tash is offline
Default Re: HELP! M-Audio Project Mix+Intel Quad6600+PTMP7.3=Distortion!
I just said the same thing to another person. Try one from SIIG. Lotta people say it works well. Mine is working good with projectmix, too.
Old 10-03-2007, 05:30 AM
RICKSTER7 RICKSTER7 is offline
Yeah, managed to buy the SIIG NN-440012-S8 (RoHS compliant)1394a
firewire card from www.tickpc.co.uk There based in Somerset.
It cost £36 including VAT & Postage to Glasgow! but it was worth it!
Good guitar signal from Project mix to PTMP7.3
Now i can get on with recording some good music!!
Thanks to all who gave me advise, cheers.
Check out one of my songs at www.broadjam.com/escapde
Rickster
Inspired Musician & Creative Designer.
http://www.escapademusic.co.uk
Old 09-22-2019, 07:01 AM
rickster7572 rickster7572 is offline
[QUOTE=RICKSTER7;1172271]Yeah, managed to buy the SIIG NN-440012-S8 (RoHS compliant)1394a
It cost £36 including VAT & Postage but it was worth it!
Rickster
Inspired Musician
'music the ultimate expression of feelings'
Old 09-22-2019, 07:02 AM
Originally Posted by RICKSTER7 View Post
Hi,Its a IEEE 1394a firewire adapter that I have not onboard (forgot to mention)The box says its (PI394A-2000 & OCHI SPEC v1/V1.1 compliant) The thing is that the firewire adapter worked fine on old pc setup, no digital distortion, pops & clicks.
The guys from Avid/ M-Audio says its a conflict with the firewire IRQ and my other IRQ.
In Bios Firewire IRQ is set to 7, but in WinXP/Pro it says its IRQ20.I have done all the things
Avid/ M-Audio suggested like take 1394a adapter out PC, restart, close, put back in other PCI slot,restart etc but no change, still getting pops and clicks.
I am now reformating Cdrive, installing different versions of Win Xp Pro and restarting again from scratch.
Can anyone tell me when usin Reason with Project Mix and PTMP7.3 on winXP Pro, whats the correct
audio settings for audio device panel? Do Reason use motherboard audio card or does it use the Project Mix audio card for midi?
A lot of times I feel everything is not explained enough in the M-audio/Protools manuals for correct setup with windows XP, as one click and you can easily muck configs up.
Thanks for the advice so far folks, All in the name of making good music!!
Old 09-22-2019, 07:20 AM
[QUOTE=RICKSTER7;1164905]Hi I have just rebuilt my PC for PTMP7.3
I have M-Audio Project Mix+ Intel Quad6600 Cpu, Gigabyte GA-P35-DS3R M/Board, 2GB Ocz 8ooMhz,520W Trust PSU,Xpert Vision 8600GTS 512Mb/128Bit/Gddr3 GFX Card,2 x 320GB Seagate SataII HDD, Windows XP Pro SPK2.Reason3,Guitar Rig2.
Firstly I do not overclock anything so that has been disabled in bios.
When I set a guitar track on Project Mix, there is tons of digital distortion and i cant record!!
I have just spent a load of money buying all these new componants and I cant record!
I checked a mix, I had done and its handling it fine, the CPU load for PTMP7.3 is way low which is great as it's a Intel Quad!
Secondly, I am getting a audio message from the motherboard saying 'Warning,Warning!'
IN Easy Tune (the m/board health check program) it shows that the CPU-SYSTEM temps are 52oC and 57oC.It also says PWR1-CPU temps are 27oC and 31oC.
Also are these normal temps for Seagate SataII 32OGB HDD; Temps are 46oC and 47oC
Can anyone help me out here as I am in the middle of recording and cant get to finish my song till
I get this sorted out. Thank you to fellow digi-friends for all advise past and present.
Rickster
Inspired Musician
  #16
Old 09-22-2019, 07:21 AM
Rickster
Inspired Musician
  #17
Old 09-22-2019, 07:22 AM
Originally Posted by myonlineportal.com View Post
what chipset of 1394 does gigabyte ds3r uses?
don't mind sharing?
  #18
Old 10-07-2019, 09:09 PM
[QUOTE=rickster7572;2538820]
Re the temperature warnings; you said you rebuilt the system. Did you touch the cpu, or the cpu cooler? Case fans? If the cooler has not been touched in a long time(that's an "old" computer), maybe you need to clean out dust buildup. Maybe the fan is getting slow(from age and dust). Maybe the thermal grease is not doing its job? Its not difficult to remove the cpu cooler, clean the top of the cpu and the mating surface of the cooler, and apply some fresh thermal paste. I don't think those temps are high enough to cause damage, so maybe check to see if Easy-Tune can be set for higher temps before sending a warning?
INFO HERE FOR GOOD 1394a WITH PROJECT I/O & PTMP7 RICKSTER7 Pro Tools M-Powered (Win) 1 10-03-2007 08:34 AM
SERIOUS HELP WITH SETUP FOR PTMP7.3 & M-ADIO PROJECT MIX !! RICKSTER7 Pro Tools M-Powered (Win) 1 09-13-2007 09:51 AM
PTMP7.3 WITH PROJECT MIX. LOTS OF DIGITAL DISTORTION? RICKSTER7 Pro Tools M-Powered (Win) 8 07-28-2007 11:31 AM
PTLE7 and Com8/Mbox2 or PTMP7 and Project Mix MarkusB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-24-2006 11:16 PM
Distortion with core audio on intel mac thesneakyjesus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-08-2006 05:15 PM
