Old 08-07-2006, 10:06 PM
voltech voltech is offline
Default digi 001 midi ports + OMS . Cant get midi to work
I was wondering if anyone can help.
I've been using my AMT-8 for years with the same OMS midi studio setup.
No probs. But now I dont have my AMT-8 hooked up and I only want to
use the Digi 001's internal midi ports to be used solely with
my MOTOR MIX. How do I configure or edit the OMS studio set up
page so I only have the MOTOR MIX working with it??
Any help is greatly appreciated!
Thanks
Voltech
Old 08-08-2006, 04:33 AM
mindnoise mindnoise is offline
Default Re: digi 001 midi ports + OMS . Cant get midi to w
HI,
you must have the MOTOR MIX profile in your PT/Profile folder to control PT with it.
Take a look at the "MIDI Controller Guide" that came with your 001.
I am not really sure if you need to configure it under OMS.
The 001 midi ports should be auto recognized by OMS if you let it search for it.
For the MOTORMIX select "New Device" within OMS and enter the name and the send/receive channels
into the device page. Refer to your MotorMix manual to see what channels are used by the
controller.
That should do it
regs
last: PT11.3.1
Old 08-08-2006, 12:32 PM
Thanks regs..
That did it!
voltech
Three MIDI ports on DIGI 002R within MIDI studio Setup Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2010 04:57 PM
Digi 002 midi ports don't work lozzi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-09-2006 10:59 PM
002R midi i/o ports dont work ezko MIDI 0 02-02-2005 08:54 PM
Digi Midi Ports not seen Iguana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-13-2004 07:38 PM
Digi 001 midi ports JahBreeze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2001 03:44 AM
