Go Back   Avid Pro Audio Community > Announcements > General
Old 12-12-2000, 08:54 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default MLCD Update for Yamaha CDRW 8424S v1.0j
From the Late Breaking Technical Issues page
MasterList CD 2.3.1cs1 Update
Fix for MLCD v2.3 using Yamaha CDRW 8424S with firmware version 1.0j
Who Should Use This:
MasterList CD v2.3.1cs1 should only be installed if you have the following components or are experiencing the dialog described below. MasterList CD v2.3.1cs1 should not be used for any other purpose. If you currently have the following components in your system you should install the update to MasterList CD v2.3.1cs1:
* MasterList CD version 2.3 application already installed on your system from the MLCD 2.3 web installer or your MLCD 2.3 application CD.
* Yamaha CDRW 8424S with firmware version 1.0j (do not use the update if you have firmware v1.0g)
MasterList CD version 2.3.1cs1 stops the following dialog from appearing (which occurs with the above combination of components) after the "Write Disc" button is pressed:
"Version 1.07, 1.08 of the CDR-100 requires copy flags on all tracks"
Download Page with Instructions
Bruce Paine
Digidesign
Administrator
HTML code is On
Newer Yamaha SCSi CDRW with MLCD Muzoid Digidesign Hardware & Software 2 12-17-2002 09:04 AM
Yamaha CDRW Ext Firewire 24x vs a 40x leon777 Pro Tools TDM Systems (Mac) 2 06-01-2002 12:35 AM
Yamaha CDRW 8424S with firmware version 1.0j Avid Digidesign Hardware & Software 2 12-16-2000 04:24 PM
Yamaha 8424S Rikk Digidesign Hardware & Software 7 04-10-2000 11:08 PM
Yamaha CDRW-4416S audiodepar Digidesign Hardware & Software 0 02-23-1999 07:03 PM
