Go Back   Avid Pro Audio Community > Announcements > General
Old 11-03-1999, 03:38 PM
Techsupt2 Techsupt2 is offline
Default Pro Control Monitor Section-Please Read
Hello,
As a result of some of the posts here regarding polarity when monitoring with the ProControl monitor section, we’ve performed tests on the AUDIO OUTPUT connector to determine if a problem exists. We have discovered a reverse polarity condition that affects the Control Room Out left/right, Slate/Dub Out left/right and Control Room ALT Out left/right connections. The (+) and (-) pin locations for these outputs on the AUDIO OUTPUT D-sub connector are reversed from what is shown in the ProControl User Guide.
Using a stereo monitoring setup as an example, if your monitor amp, powered monitors etc. inputs are wired as pin 2 hot (+) and pin 3 cold (-), the corresponding pinouts on the ProControl AUDIO OUTPUT connector (Control Room, Out left/right, for example) would be sending these signals as pin 3 hot and pin 2 cold. The simple "fix" for this is to reverse the pin 2/pin 3 locations at the XLR’s of your cable assembly. There are also commercial turn-arounds available for this purpose from companies like Switchcraft and Whirlwind. If your cable harness fans out to *" TRS phone plugs, reverse the tip and ring points.
We apologize if this has caused any inconvenience. To ensure all ProControl users know about this, we will be sending out a letter to all registered users in the near future.
Digidesign Product Management
HTML code is On
Control Monitor Section STILL Intermittent! a2zproductions ICON & C|24 3 11-07-2008 09:29 AM
PLEASE HELP!!! Control 24 Monitor section SURGING!!! Table Syrup Records ICON & C|24 2 01-07-2008 07:56 AM
Upgraded monitor section on a Pro Control? joesgarage ProControl, Control|24, Command|8 2 10-16-2006 05:31 PM
control 24 monitor section woes insolace ICON & C|24 4 05-18-2005 09:30 AM
Monitor control room section Tomio Broman ProControl, Control|24, Command|8 1 05-19-2003 10:57 AM
