Smpte
I'm trying to sync PT with incoming timecode. I can see the timecode in my session setup but somehow I can't get PT to follow the timecode. My setup is a Profire 2626 & M-audio Midisport 8x8S. The Midisport is receiving the incoming timecode from a timecode generator.
Any ideas how I can get PT to lock/follow incoming timecode? |
Re: Smpte
Did you enable the Online button in the transport window?
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: Smpte
I managed to get it to work. It was a frame rate issue that I had to change in the session setup. It had to match the number the frame rate from the timecode generator
Re: Smpte
Understand that what you're doing is "lock and release" sync, and it will drift over time since PT isn't synced to the external source's clock. How much? Who knows, it depends on the difference in the two clocks. This is all in the other thread you posted in and linked threads.
MTC-To-SMPTE/SMPTE-To-MTC Interface - What do YOU use? | Nawlins | Post - Surround - Video | 5 | 03-20-2008 02:55 PM |
SMPTE with PT LE | ***BBOY*** | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-20-2005 09:18 PM |
OT:SMPTE, LTC, MTC.... | 1150Post | Post - Surround - Video | 8 | 11-14-2003 11:44 PM |
I have SMPTE in LE | Mark Reis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 36 | 05-02-2002 10:03 AM |
SMPTE...again | arb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-23-2002 12:34 AM |
