Reverb busses outside of Low-Latency mode in PT12
Hello friends! I'm new here and hoping some qualified professionals can assist me with a problem I'm having. I'll try to explain my set-up and signal chain first.
When tracking vocals, sometimes I try to create a little bit of the finished result in my vocalists ears. Typically, I don't like doing this because it can cause pitchy performances - but with other people they are able to perform better with effects added. I have a Neumann TLM103 going into the first channel of my UA 4-710d. I'm inserting my EL8 Distressor and pushing that signal to my Apollo Twin. At this point, I'm adding a Pultec EQ and an LA2A into the insert path in the UAD Console. After this, it's going directly into Pro Tools with no effects inserted in PT. At this point, everything sounds excellent. However, I can't seem to add a reverb without turning Low Latency off. When I do this, the vocal sounds like a double. Almost like I turned on a 0.20ms slapback delay. I'm confident this has something to do with latency, and I'm wondering what the workaround is. Any thoughts on how I can add reverb without this weird doubling sound? Thanks in advance! |
Re: Reverb busses outside of Low-Latency mode in PT12
do you have a mix control on your verb ... turn it to Full Wet !!! maybe ...
I should have been clearer, but prior to any reverb I have a weird vocal latency sound. Like it has been doubled, or sounds phased. This happen immediately after I turn off low-latency.
This being said, you are correct that a reverb without full 100% wet would imitate a similar sound. But that's not the case here, as I'm not able to solve the doubling sound via monitoring vocals. |
I think maybe the delay comes from the inserted reverb is not 100% wet?
I'd make a aux track, input set to the mic, and the reverb plugin set to 100% wet. (It will have the 20ms, as a kind of reverb pre-delay.) Oh, and welcome to the DUC. |
Very helpful Drew and Ben! Thanks for the insight and the warm welcome. I will try this and report back on results. Thanks again!
Of course you could make a reverb send in Console and leave PT in LLM. And also have a verb setup in PT. During pre roll and post roll, your verb in PT should still be active, and during the punch the Console verb would make the singer comfortable. Try it.
I track everything at the 64 buffer and have not used LLM in years. Now I also often track 2 tracks for vocals, but mine are usually 2 mics. Whenever I do this, 1 of the 2 tracks stays muted(the producer can decide later on which mic is preferred). My vocal reverb is always on a stereo AUX track, fed by a send. Headphones are fed by sends on all tracks(I fill a bank of 5 sends out to 5 separate mixes for players). Reverbs are always set 100% wet
I don't currently use a console, but I do basically the same thing using an Aux track with the same source as the recorded track. This is also nice in that I can hear the singer if they say something to me during playback. I also use reverb at 100% wet on an Aux track fed by sends so that I can adjust the reverb level fed to the vocalist's mix independent from my control room mix.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yes. If you're running vanilla, kill input monitoring on your vocal track in PT so you can hear only the direct monitored signal from your interface.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
PT12 Track Output Busses Changing | JamesDrake | Pro Tools 12 | 1 | 12-08-2015 04:11 PM |
What busses do you use for reverb | tokolosh | Post - Surround - Video | 3 | 09-22-2010 06:01 AM |
Tracking Vocals with Reverb in Low Latency Mode? | micline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-02-2010 05:36 PM |
TRACKING w/ REVERB PLUGIN in LOW LATENCY MODE? | minor2nd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-10-2005 01:27 PM |
Reverb on rec enabled tracks with low latency monitoring mode | mixaudio | Tips & Tricks | 0 | 06-16-2001 08:09 AM |
