UA plugs in 7.3?
Anyone using UA TDM plugins in 7.3?
-s0nguy |
Re: UA plugs in 7.3?
No one uses them in 7.3?
-S0nguy |
bump
I'm using UA TDM plugs on PT 7.3.1 on a Mac and its rock solid so far...
I just upgraded to 7.3.1. I've pulled up the LA2A and it looks like it still has the graphic issues. I haven't done any extensive testing yet.
Are you having an issue with the plugs? |
Hello s0nguy,
I´mm using one UAD PCI card with PT HD 7.3.1 on a AMD Opteron 4 GB machine with a Tyan Thunder Board. Unfortunatly this is a system marked as reference by Digidesign, but got an incompatibility issue with the UAD PCI cards due to the AMD 8131 PCI Bus controller. Nevertheless I use the UAD card in PT with the Precision Multiband (which is outside any PT delaycompensation range) and the world best chorus emulation, the Roland CE1. If I use more than one or max two plugs, I often get an PT error, order me to lower my RTAS load. UAD support told me, that this issue should be solved with the new PCI E cards, still strange, that Wavelab runs a lot more UAD PI´s as PT does, seems to be caused by PT PCI bus load. Hope that helps, greetings, Goetz. |
Native Instrument Plugs vs Stock PT-10 Plugs | PatriotsBiker | AAX Plug-ins | 8 | 02-04-2013 11:19 AM |
Plugs | Oscartrap | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-12-2011 07:42 AM |
Where are my Plugs??? | Craiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-04-2008 11:09 AM |
HD and RTAS Plugs, Why Buy TDM Plugs | Barry Johns | Pro Tools TDM Systems (Mac) | 3 | 06-01-2007 08:29 PM |
What plugs then? | Jonah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-23-2003 10:44 AM |
