Old 12-21-2016, 03:00 AM
Zoduati Zoduati is offline
Default PT12 with Digi003 Console - Automation Problem
When attempting to mix volume levels via the touch-sensitive faders on the Digi003 console, the playback volume/s of the channel/s I am automating do not play instantly with the new levels, but instead, play back the original levels until I actually rewind and playback to hear the changes.
This is quite useless, because I cannot hear the changes I am making until I replay.
(I previously used a Digi002 console which had no problems like this.)
Could there be a setting I have incorrect that is preventing this automation working as it should?
thanks,
Geoff
Old 12-21-2016, 05:08 AM
justus1900 justus1900 is offline
Default Re: PT12 with Digi003 Console - Automation Problem
Following: My Digi 003 Console the faders have never worked. Everything else works but the faders do not follow the Automation or any Moves I make on the console faders, I always assumed it was the driver not being set up to do that?
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 12-21-2016, 04:11 PM
My Digi003 follows the automation on playback, it just doesn't follow it when writing.
I am not sure what to suggest however to improve your experience, if you have the same drivers (most recent). However, I'm on a Mac (Yosemite).
regards,
Geoff
Digi003 (Console) + Automation [solved] Zoduati Pro Tools 11 2 07-06-2017 08:50 PM
PT12, Digi003 Console Automation Zoduati macOS 0 07-12-2016 06:12 AM
digi003+ and pt12 and macbookpro connections qwert1964 Pro Tools 12 0 09-24-2015 09:05 AM
Digi003 Console, 10.3.6 and the new Avid 003 driver TimR Pro Tools 11 3 06-23-2013 08:23 AM
Windows 7 64bit / Digi003 Console krazylain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-21-2010 04:03 PM
