Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 06-20-2016, 07:30 PM
justus1900 justus1900 is offline
Default M-Audio ProjectMix I/O Windows 10 No Sound
I have a M-Audio ProjectMix I/O running on Windows 10 and for some reason I cannot get any sound to my speakers, I have gone into the Control panel> Sound and changed every setting I can think of but when I press play I can see the session is playing but it doesn't show any audio in the sound section, now if I open a browser and play YouTube I can see the sound is going into the windows sound the meter shows audio movement but I can't make that sound come out of my monitors either, I have checked the monitors and they work, I reloaded the firewire drivers the Projectmix HUI works perfect but No sound, I'M thinking it some Windows sound setting but I'M lost, Please Help Thank you
Producer/Engineer/Musician
RIAA Platinum Sales Award: Lisa Stansfield "Affection"
Main:
Model: Dell 5750 Precision Workstation
OS: Windows 11 Pro 64bit
CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz,
Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC
OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD
Focusrite Scarlett 18i20 3rd Gen
AVID Pro Tools 2023.12
JBL LSR4328P 8"
JBL LSR310S 10 inch Powered Studio Subwoofer*
Yamaha HS50M Studio Monitors
Alesis Elevate 3 Studio Monitors
M-Audio Axiom 61 Midi Controller
Old 06-20-2016, 08:43 PM
Default Re: M-Audio ProjectMix I/O Windows 10 No Sound
Changing every setting you can think of is not really a good method of troubleshooting. Step by step:
1-make sure you have installed the latest driver
2-Go to Control Panel>Sound>Properties and set Windows to NOT use the PM as its default playback device(so only Pro Tools uses the ProjectMix)
3-hold the N key while opening Pro Tools to navigate to the window to select the "audio engine" and select the Project Mix(if its not already selected).
If none of this helps, check the link above named Help Us Help You and paste a Sandra report as you may have an incompatible firewire controller(Most audio apps work best with a TI chipset for firewire), Dells can be a crapshoot regarding FW controllers, and general compatibility.
Old 06-22-2016, 05:50 AM
bradch00 bradch00 is offline
Which driver are you using for Windows 10? There have been a few people reporting success with the last Windows 7 driver. No guarantees as the unit was dropped from support a few years back.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 06-22-2016, 07:46 AM
JoelG's Avatar
JoelG JoelG is offline
Mine is working fine in Win 10, using the last Win 7 drivers. I'm guessing it is something with routing in the M-Audio control panel..
Also, I make sure Windows doesn't use my audio interface for any computer sound (Windows, YouTube etc.), as that can interfere with the ASIO connection to my DAW.
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 07-09-2016, 09:18 AM
I finally gave up on the M-Audio Projectmix I/O and bought a Digidesign Digi 003. The Digidesign Digi 003 worked perfect from the start, loaded the drivers and it worked perfect, plus it doesn't disconnect from the computer sound and HUI all the time requiring reloading of the drivers and reconnecting the firewire connection... Just my Two Cents... Glad to have my studio back up and running without all of the problems I personally was having with the M-Audio projectmix I/O, Thank you
Main:
JBL LSR4328P 8"
M Audio ProjectMix I/O peter5992 Post - Surround - Video 2 09-16-2012 08:22 PM
Projectmix I/O running on both Windows Vista and Mac Leopard thglif52 Pro Tools M-Powered (Win) 0 03-29-2010 12:30 PM
projectmix not being recognized in windows vista anymore wreckthisplace Pro Tools M-Powered (Win) 3 10-24-2008 06:09 PM
003 vs. M-audio projectmix I/O sos4e 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-09-2007 03:16 PM
M-Audio ProjectMix I/O Hogie Pro Tools M-Powered (Mac) 6 10-11-2005 08:33 PM
