Old 05-28-2012, 07:30 PM
sjtae sjtae is offline
Default why external vu meter/ plug-in vu meter differ?
I am using external VU reference meter, RMU25.
I did calibration as a reference level 20 for external vu meter.
Also, I used plugin Bomb Facotry's meter bridge and set calibration level at -20.
The indicating levels of both signal test with sine wave were perfectly same.
However,
when I playback audio, Bomb factory one indicates higher level than external.
(tried both music and voice/ rms and peak)
I don't know why they indicate different levels.
As I know, all VU meters follow a standard level.
Does anyone know the reason?
If it is reasonably right, what do I need to do to make them at the same level?
Old 05-29-2012, 11:30 AM
Craig F Craig F is offline
Default Re: why external vu meter/ plug-in vu meter differ?
all BF meter plugs are broken, have been from day 1
the running joke is: Bomb Factory Essentials are Essentially Useless
Thank you,
Craig
Old 05-29-2012, 02:09 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default
Broke as in out of cal or broke like not usable b/c of random errant levels?
Daniel
Old 05-29-2012, 11:12 PM
elicious elicious is offline
the two most accurate vu meters i seen for ptools
are the free psp vintage meter
(but broken on macs since intel),
or the pay for (but worth it)
metering on the slate fg-x.
both will track like analog boards/decks.
b.o.l.
e
ihatetyping
Old 05-31-2012, 11:09 AM
out of cal
Thank you,
Craig
Old 06-03-2012, 09:46 PM
Thanks for reply.
Do you mean there should not have any diffrence?
The problem is just cuz of the BF meter.. isn't it?
Old 06-03-2012, 09:54 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
-3 difference on the Bomb Factory.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 06-05-2012, 09:16 PM
YYR123's Avatar
Default
So -3 on the BF is 0 vu on most good meters ??? Just checking
Daniel
Old 06-06-2012, 05:50 PM
-3 is what I constantly seem to get with ITB VU meters (Bomb Factory, PAZ and VMeters), unless I run them with a K weighting setup. (Google Bob Katz for more info on that).
The inbuilt phasescope has a VU setting which shows -20tone as 0VU, but the ballistics are crazy when it comes to audio program, (Meters about 3db hotter than K system).
Inserts affecting send meter but not channel meter? Kbrinson85 Windows 1 05-01-2012 07:00 AM
RTW external meter and C|24 controller GusNL ICON & C|24 1 04-15-2009 12:44 AM
PTHD8 cpu meter vs task manager cpu meter MEAT Pro Tools TDM Systems (Win) 5 01-02-2009 05:17 AM
New Meter Plug-in Rail Jon Rogut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 33 08-26-2005 03:46 PM
Phase meter plug steveG Pro Tools TDM Systems (Mac) 14 12-25-2001 02:54 AM
