Old 12-16-2011, 06:14 PM
Stixntrixx Stixntrixx is offline
Default No Sound - Going Crazy!!!
Hi Everyone,
So I'm running a 001 on a Dell Dimension e510 using XP and PT LE 6.4. I just had a major computer crash but it was saved when a friend installed a new power supply and fixed a "transistor" on the motherboard (not sure what that means, but that's what he said). Now the computer starts up just fine and works perfectly except I can't hear any sound. I've always been routing all audio playback programs through 001 using the the MME Helper. But now when I launch an mp3 via Windows Media Player, it looks as if it is playing, but I can't hear anything. Same with streaming audio/video. In the Device Manger there is a yellow exclamation point next to the 001, so I uninstalled and reinstalled the 001 and still no luck.The 001 doesn't even appear as an audio device in the drop down menu in the Sounds & Audio Devices section of the Control Panel (but SigmaTel Audio does). When I shut off and restart the computer, I can hear the speakers pop, indicating at least there is a connection between them and the computer. But no sound otherwise. Any ideas? Thanks.
Old 12-16-2011, 06:23 PM
Top Jimmy's Avatar
Default Re: No Sound - Going Crazy!!!
Originally Posted by Stixntrixx View Post
In the Device Manger there is a yellow exclamation point next to the 001...
Expand the entry and see what the error code is.
James Cadwallader
Old 12-16-2011, 10:24 PM
Thanks for the response. The error code is 10. This device cannot start.
Interestingly, after multiple restarts the sound finally came on. Lasted for about an hour. Walked away from my computer for a bit and sure enough the sound went away again and is still not present after multiple start ups. It seems like for some reason the 001 isn't initializing at start up and if it does, it's just random and temporary. Hope this helps :)
Old 12-18-2011, 04:44 PM
Top Jimmy's Avatar
I hate to say it but the problem could be with the card or PCI slot. You could try moving the card to an alternate slot and keep your fingers crossed.
James Cadwallader
Going crazy over sound-quality in PT vs Logic timeey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 91 03-26-2018 02:14 PM
Am I Crazy Or Does Pro Tools 10HD Sound Different from HD9? rabben82 Windows 0 01-09-2012 01:00 PM
Please Help! Pro Tools 10 sound going crazy BGH Pro Tools 10 6 12-19-2011 04:14 PM
Crazy Sound Contest !!! digiwan General Discussion 9 03-28-2010 05:23 PM
Crazy metallic sound in heaphones..please help! elwoodblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-10-2003 12:09 AM
