Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 12-13-2009, 08:52 AM
Jonasfp Jonasfp is offline
Default Internal SATA vs Firewire
I have a PC, what would you suggest as extra pro tools storing drive, SATA2 or Firewire?
A Seagate 7500rpm Sata comes at a much cheaper price than a Firewire LaCie.
Old 12-13-2009, 11:01 AM
sunburst79 sunburst79 is offline
Default Re: Internal SATA vs Firewire
I like internals
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 12-13-2009, 11:30 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Internal SATAs are also stupid easy to swap out and archive.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 12-13-2009, 11:38 AM
Excellent :) Sata it is then. Ill probably have to det rid of my RAID system drive, and just go normal 2xHD ?
Old 12-13-2009, 12:23 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Yeah u wanna get `det` rid of raid asap as it isn't supported...will it work? Yeah, but that risk is on u & as u see, its really not even a comparison between sata & firewire IMO...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 12-13-2009, 02:20 PM
Meaning that Firewire is better than SATA as audio-disk? :) sorry I need to get it written on the wall.
Old 12-13-2009, 04:04 PM
NO! where did u get that out of all the post?
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 12-13-2009, 04:31 PM
As I said needed to get it painted, sorry ;p. Gonna go tomorrow and get a new sata2 HD. I have a normal sata 16mb cache. Should I use that as system ot audio drive?
Old 12-13-2009, 06:39 PM
What I would do would be to buy 1 new drive. Use a disk cloning utility to clone whats on your RAID array to the new drive. Then split up the RAID array and use the two drives as your recording drive and a spare, backup or samples drive.
This assumes you can find a disk utility that will copy a RAID volume. I tried this with a RAID5 array and didn't have any luck. Supposedly some disk utilities will clone a RAID array as its not the sole bootable drive in the system. I never tried installing XP onto a fresh drive and then booting from that. Some expensive enterprise level disk management suites will let you clone an array but I ain't spending 500.00+ bucks. I tried Acronis Disk Director, True Image and Norton Partition Magic to no avail.
Scott
Core 2 Specs Page
Old 12-14-2009, 12:44 AM
M-ManLA's Avatar
M-ManLA M-ManLA is offline
SATA II all the way if you can help it. Even though most hard drive won't saturate the whole 3Gb that SATA II offers, it will be a lot faster and snappier than a Firewire 400Mb drive. Also in the Pro Tools world, they support 24 tracks on Firewire, 32 on SATA II, which it can do more than that. SATA II all the way. I would suggest you use a RAID1 configuration ONLY for back up on another system, server, or external drive just to back up your work. As far as your workstation, use no RAID on the audio drive.
www.M-ManLA.com
www.facebook.com/MManLA
www.soundcloud.com/m-manla
Pro Tools 12, Sibelius First 7/Presonus Studio 192/Windows 10 Pro
Better to record to a FireWire drive? or 2nd Internal SATA HDD? conrad787 macOS 13 06-21-2012 08:52 AM
Glyph external firewire or Internal Sata 11 for recording mal777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-13-2008 11:35 PM
Recording to internal sata or external firewire drive? Mcgrathx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-28-2008 09:50 PM
recording to 2nd internal SATA vs firewire 372cat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-17-2007 08:14 AM
Internal SATA versus External Firewire scoobydoo Pro Tools TDM Systems (Mac) 8 08-31-2006 11:29 AM
