#291
Re: The Official Unofficial Windows 7 Thread
#292
Hi Benoni, I got PT 8 and all of it's goodies installed. All is running well but I cannot use the MBox2 Pro at anything faster than 48 khz. Have tried the default driver in various configurations and with various steps but I get the dreaded 6006 error. I get the same error when I try the other two sample rates. With the legacy driver I get 44 and 48 fine. I have a very new MSI motherboard and the IE1394 is incorporated. I am wondering if a pci firewire card may help this issue. What are you using and what do you think?
#293
I power on my system all is fine, but Host light in my 003 start blinking for a long time,so i went to device manager to check 003 appears and all is right, then open PT, Host light stop,wathever after open PT all is fine and working You mention it,is the same case that you mean?? What i say is after averything. beside I also use the Standard driver from my Notebook for the firewire port. All my plugins works
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
#294
It Finally Worked! I did the 8.0.3. for LE and voila!!! I took some doing, but I am up and running!
#295
This is going to sound retarted but.....I did get everything working! My Pro tools 8.03 and Mbox 2. I am use to an older version of Pro Tools. When I plug my guitar into the Mbox 2 I can hear it and the level meter shows it, but when I start recording the track nothing records and it does not pick up anything, but I can still here my guitar. Ive tried doing intrument tracks and guitar tracks. I am using "stereo". Ive tried using all the inputs and still not recording my guitar. I know it is probably something simple, but I dont remember.
#296
First off, I want thank you Benoni for all the advice in this thread. I have been pouring through it for about a week now trying to get this new latop to run PT LE. I have made some big strides.
This system is a HP Pavillion dv7 (model dv7-3098ca). Its runs an Intel i7 @ 1.60 ghz, 8 gigs of DDR3, it has 2 internal 500gb drives @ 7200rpm. Im running PT 8.0.1 in win7 x86. I have followed all the optimization guidelines described in your last post as well as the videos you posted on vimeo a few pages back. Currently my problem is two conflicting error messages. -(9129) Audio processing is conflicting with other CPU tasks. Reduce "H/W buffer size." -(9092) The operation system held off interrupts for too long. Increase "H/W buffer size." The erros alternate depending on wether I increase of decrease the buffer. I saw a previous post from a user who's name escapes me now, that he was trying to install on a very similar HP laptop (dv5). You responded that "it looks fine, except for he needed a drive" or something to that effect. I assume you mean he needed an external drive. Could that be my problem, why? Would an external firewire drive solve my problem? Any help would be greatly appreciated. I have until Jan 3rd to return this beast of a laptop. I don't want to get a rediculously over priced macbook pro unless I have to. |
#297
Well everything was working perfectly fine yesterday. I started recording guitar and bass tracks. Today I booted up my computer and started to record. Now after I record a track and playback my guitar sounds like complete static and muddy. Sounds horrible! But when I am not recording and just playing the guitar it sounds normal. It is only after recording. And the click track always sounds muddy and with static. Something must of happened. ANybody know?
I checked the cables on my Mbox and they are fine. |
#298
Hello fellow Windows 7 users! I'm new to Pro Tools, so forgive me if I sound like an idiot. (I couldn't even figure out how to start a new thread.) I would love any advice you could give me about installing Pro Tools. Here's the mess up to date:
I bought Pro Tools LE just as Windows 7 came out, and then bought a new laptop with Windows 7. Digidesign just released the update to run Pro Tools on Windows 7 so now I'm finally trying to install. At first I tried just downloading the 8.0.3 update, but it wouldn't work and said I needed to download 8.0 first. I have done that, but in the setup, it says I am missing an MBox 2 Driver. I found this on the site: To update your Mbox 2 drivers on a Windows PC: 1) Obtain the update kit: If your Mbox 2 came with Pro Tools 7.0 software, the Mbox 2 Firmware Updater is located on your Pro Tools 7.0 CD in the Additional Files\Unsupported Software folder. The firmware is also available at the Digidesign Web site: (http://www.digidesign.com/download/mbox2). I followed the directions, but got an error message saying the driver couldn't be installed because there was not a valid version of Pro Tools LE on the system. Help!! How can I install 8.0 to then install the update if the drivers I need to install it need 8.0 to be installed in the first place? Should I install the old version (7.3) that I have the disk for first, then upgrade to 8.0, then upgrade to 8.0.3? I don't want the installation to crash my computer because it's running Windows 7. I would appreciate anything you can tell me. I'm really really excited to use this stuff, but keep running into dead ends. |
#299
Dumb***** question time....
Any reaosn why I'd go to Win7 pro or ultimate for running protools on my laptop instead of home premium??? (dedicated live recording/playback machine - I only run Protools, Sonar & Showplay on this machine). Any compelling reason why I'd upgrade my main puter past home premium?? Cheers guys & have a happy holiday season!! |
#300
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
THE UNOFFICIAL "DAVE C" TEST RESULT THREAD | scuzzytim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 79 | 07-14-2010 08:21 PM |
The unofficial PTLE bottom-feeder thread! | M.Brane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 07-18-2006 06:07 PM |
unofficial "Problems with PT7" thread | nikki-k | Pro Tools TDM Systems (Win) | 68 | 05-02-2006 01:00 PM |
---unofficial BTD report only thread--- | nikki-k | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 59 | 12-02-2003 04:29 PM |
