Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 08-06-2009, 05:22 PM
MOGAZI MOGAZI is offline
Default Recurring Problem with Lacie D2 Quadra Firewire. Daisy chaining FW400 and FW800?
Hi there,
First of all here's my setup: IMac G5 (1 FW 400, 1 FW 800), Lacie D2 Quadra (1 FW 400, 2 FW 800), Digi002 (FW 400).
At first I had both the Lacie and the Digi002 connected directly to the computer respectively via FW800 and FW400. Unfortunately after just a couple of months the FWPorts on the Lacie died (USB working fine).
I sent it for repair and when I got it back I daisy-chained as follow:
iMac-->FW400-->Digi002-->FW400-->Lacie
But in this configuration the drive lasted even less. After less than a month I got a message saying the drive had been improperly removed and the firewire was gone again. Now I'm waiting for them to fix it yet another time. But I'm wondering if I'm doing something wrong...
I know Digidesign recommends to place the drive between computer and Digi002 but that was the only way I could daisy chain using FW400.
Would it be possible to connect:
iMac-->FW800-->Lacie-->FW400-->Digi002
or would it be better
iMac-->FW400 adapter to FW800-->Lacie-->FW400-->Digi002
Thanks!
Old 08-08-2009, 12:52 AM
mix109 mix109 is offline
Default Re: Recurring Problem with Lacie D2 Quadra Firewire. Daisy chaining FW400 and FW800?
I would stay away from sidechaining the 002 and a Hard Drive(especially Lacie)
The so called FW Hub of the 002 is not what i would call reliable.
Also have in mind that the iMac(2) FW ports are based on a common bus also.
Since there is no other workaround connect each device to each FW Port,or use the Int Drive for rec and the Lacie or whatever for Backup.
Old 08-10-2009, 04:26 AM
cheekypaul cheekypaul is offline
The correct chaining for you would be IMAC-002-HARD DRIVE, all using the fw400 connection. i suspect the the fw400 and fw800 are sharing power, so use one or the other.
i use those d2 drives and they have never let me down. when i read about peoples problems with them i wonder if i've been lucky for 5 years and 12 drives.
Mac Computers/PT12/Lots Of Lacie D2s
Old 08-14-2009, 03:46 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
+1!
I also use the Lacie D2 drives for many years without any problem.
But the other cheaper LaCie drives (Porche design, etc) I wouldn't trust, they run much too hot and just stop working
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 08-14-2009, 04:05 AM
...But the other cheaper LaCie drives (Porche design, etc) I wouldn't trust, they run much too hot and just stop working
yes +1 re: porsche etc.
the bus-powered drives are an absolute no-no when it comes to intensive drive activity. they will fail if pushed too hard. fine for storage, itunes. etc., but not for any integral work.
LaCie d2 Quadra V3 - new firmware to solve firewire issue jakas Pro Tools 9 2 01-11-2012 01:37 AM
Daisy-Chain Lacie Quadra HDDs jdubbs77 Storage Subsystems 1 09-02-2010 09:00 PM
Daisy-chaining multiple drives FW400/800?? RandB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-12-2008 03:53 AM
Please help! FW400 vs FW800 external / Lacie vs.. besmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-11-2003 12:11 PM
OT:Can u daisy chain FW800 and FW400 external HDs? Alex Rodriguez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-03-2003 09:27 PM
