Old 11-19-2008, 09:49 AM
MASTERLINKSTUDIOS MASTERLINKSTUDIOS is offline
Default Video plays in session,but timeline isnt moving with video
this is happening in my le system,digi003 rack mac pro dual 2.66 5 gig ram,dv toolkit 2.it worked before but when i press play it takes a while for the video to play,but the counter doesnt move and timeline stays still.i can press a button next to quicktime video,then video wont play,but everything else will work perfect then.please help anyone.what changed????
Macpro 2.88-4 Gig Ram,HD2,Big Ben,Rosetta 200,Dangerous D Box,Mercury Bundle + Studio classics bundle ,C/24,2-UA 6176,U87ai,Genelec 8050 & 8020,Logic,Final Cut Studio 2,Canon hxa1(hd camera)-Macbook Pro,Mbox 2 Micro.http://www.masterlinkstudios.com/.http://www.myspace.com/masterlinkstudios
Old 11-19-2008, 10:15 AM
BradLyons BradLyons is offline
Default Re: Video plays in session,but timeline isnt moving with video
Video playback can be a strain on the computer. What resolution is the QT file?
Thank you,
Brad Lyons
www.howavl.com
Old 11-19-2008, 11:46 AM
DigiTechSupt's Avatar
In Preferences, set the video playback priority options to something other than 'Highest'.
Avid Audio Tech Support
Support FAQ
Old 11-19-2008, 12:23 PM
ive set the video preference to the lowest setting,and the video is playing and timeline moves(numbers and all,but it takes about 5 seconds to play after i hit space bar.before i upgraded to 7.4 everything worked well.there is a problem,because this same thing occurs with my hd system and le system.digi you guys need to fix this cause why would someone buy new complete production kit for 2k and things dont work smooth.FIX THE PROBLEM DIGI.FIX THE PROBLEM DIGI.
Old 11-19-2008, 12:41 PM
Are you sure you have plenty of system resources? I see you have a Universal Audio Card, the SSL Duende, etc...those take system resources to another level. I am running a Pro Tools HD3 Accel and the projects I have video I'm running around 100-channels of audio, feeding the video out via DVI to a 32" LCD TV with NO sync issues. I am on PT7.4cs8, although I'm one one of my Creation Station PC computers. Have you trashed prefs? When's the last time you've re-booted? Sometimes when video runs sluggish, a re-boot clears it out.
Thank you,
Brad Lyons
www.howavl.com
Old 11-19-2008, 12:44 PM
Slim Shady Slim Shady is offline
Lots of good ideas here already. Would also be interested in knowing what format the Quicktime video is, it might be that it's too compressed and the resources to un-compress are to great for instant playback given all the other stuff going on in your rig. I use video with LE on a daily basis and have never had any problems, but I stick with uncompressed DV format in order to keep resources free.
Old 11-19-2008, 01:08 PM
RussUK RussUK is offline
Codecs can make a lot of difference, make sure you have created the video in the right format. I'm with Slim I use video every day without any issues, but you do have to make sure you have the right one. Can you yousendit to me at [email protected] and I'll take a look at the video.
I work with amazing people who do incredible things.
Founder of the Expert Sites.
Old 11-19-2008, 01:57 PM
Another thing to check is that your Sound control panel is set to 'Built In' (and not Digi HW) for both input and output.
There's a known issue with video playback delay if either of those are set to Digi HW while Pro Tools is running.
Support FAQ
Old 11-19-2008, 02:27 PM
Thanks for your response digi,that did the trick.thanks so much your the best
Imported Quicktime video plays back too fast Jigatnu Pro Tools 11 3 08-17-2013 05:45 PM
Sharing a video in same session for ADR (video in booth and video in control room) Boogie457 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2010 04:52 PM
Video question 2: Changing video formats in session johnnyv Pro Tools TDM Systems (Mac) 1 03-18-2010 09:56 AM
Quicktime bounce plays audio, but no video! crizdee Pro Tools TDM Systems (Mac) 2 04-20-2007 04:34 AM
