Can\'t read full message in message boxes
Hi just wondering if anyone had the problem of when a message box appears or pop up box eg. logging out without saving the session and pro-tools asks you if you want to save that you can't read all the text in the box, it cuts off the last line or the bottom of the last line. Weird I know but I get it all the time. Just got xpand and it does it in that plugin as well. Is there a viewing setting that I can change?
J.T MB Pro 2.4 OSX 10.5.6 Mbox2 |
Re: Can\'t read full message in message boxes
I fixed it!! It's in the windows settings not anything to do with pro-tools.
Go to Display properties - Settings - Advanced - under the general tab, make sure your DPI settings are set to normal, if you choose large it will affect your view in pro-tools. Hope this helps you if you had the same problem. Cheers, J.T
bought a bigger hardrive and still get the -34 a disk is full message. | Henrydm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-28-2010 09:58 PM |
6.01 installation fails at end... disk full message?? | bdeivert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-10-2003 05:52 AM |
"full frame MIDI message" what's this??? | donpietra | Pro Tools TDM Systems (Mac) | 10 | 01-09-2002 12:23 AM |
"full frame message" what's this??? | donpietra | MIDI | 2 | 01-04-2002 01:23 AM |
"full frame message" ??? HELP! | donpietra | Pro Tools TDM Systems (Mac) | 0 | 12-28-2001 09:05 AM |
