Old 07-25-2013, 09:39 AM
grfrgr grfrgr is offline
Default A way to control EQ (Equilibrium) parameters with the 8 Rotary knobs
Dave from DMG Audio was kind enough to show me a way to map Plugin (Equilibrium) parameters to each knob you want on of the 8 rotary knobs.
I know it works with some other AAX plugins..
Basically you need to go to (Mac) Avid>Pro Tools>AAX Plug-Ins>select the plugin you want, right click, Show Package contents, find the PageTable.xml
open it with an editor (I use BBEdit) locate the parameters you want and then change their order to the order you want them to appear.
The only odd thing is that between each four knobs you have to set 4 parameters you aren't going to use and then skip to the next four parameters.
Good Luck.
Old 02-25-2014, 12:15 AM
bassmagnetic bassmagnetic is offline
Default Re: A way to control EQ (Equilibrium) parameters with the 8 Rotary knobs
Is there a way to do this on a PC?
Old 02-26-2014, 03:18 AM
b.riesel b.riesel is offline
is there an option to change that in logic too?
Old 02-26-2014, 07:03 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
As far as I know the XML files are the same in windows AAX plug-ins.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 03-11-2014, 02:20 AM
I contacted Dave Gamble of DMG Audio regarding using the Euphonix Eucon Artist series in order to control EQuality...
His answer, which seems to cover more that just Equality, I'm guessing all DMG plugins from the wording, was "I don't recommend using the artist series to control plugins."
Which is a shame, I find it is so much more easier, quicker and accurate to adjust an eq with physical knobs...
I tried the Brainworx Digital EQ and really like the way it works with the Artist Series
Rotary knobs on my c/24 are malfunctioning panni ICON & C|24 0 05-24-2013 08:50 AM
Assigning knobs to Pro Tools parameters prickstein Pro Tools 10 17 08-28-2012 10:07 AM
Faulty rotary knobs in Procontrol audiwiz ProControl, Control|24, Command|8 2 03-29-2010 03:28 PM
Crooked Axiom Pro rotary knobs - normal? UltraNEO* 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-20-2009 11:44 PM
flip of plug-ins rotary knobs, is it possible? Enrico Donner ProControl, Control|24, Command|8 10 03-03-2004 10:53 AM
