Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-30-2015, 05:44 PM
[email protected] wayfarer92@yahoo.com is offline
Default Audio signal positive will not record
I have a audio and can see the signal in the meter but have no waveform and nothing's recording...no playback. I'm record enabled and in D mode. Any suggestions will be helpful.
System Info:
Pro Tools MP9
Interface: Fast Track Ultra 8R
MacBook Pro
OS 10.6.8
Processor: Intel Core 2 Duo
Processor Speed: 2.4 GHz
Number Of Processors: 1
L2 Cache: 3 MB
Memory: 4 GB
Bus Speed: 1.07 GHz
Old 09-30-2015, 05:47 PM
Southsidemusic's Avatar
Default Re: Audio signal positive will not record
Hi and Welcome
Some info would be my first sugestion.
Start here please and provide all the system specs and OS version aswell as All the Computer specs and PT version, interface and what ever else you have in the signal chain otherwise no one can give any help.
http://duc.avid.com/showthread.php?t=300050
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-30-2015, 05:58 PM
Thanks Southsidemusic... I updated original posts with specs.
Old 09-30-2015, 06:06 PM
Goto settings in PT and choose i/o and there press default on ALL tabs like In/Out/Aux on both Input and Output and see if that helps,
Also Start PT first and hold down the "N" key and make sure you choose your interface when the popup window comes on and after that go tonsettings and do the steps i posted.
PS. What is "D Mode" ?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-30-2015, 06:20 PM
Tried all recommendations and still nothing. I can see the signal coming in the meter, hear the audio in the headphones. But when I record I don't see a waveform and there's no audio when I play back.
Old 09-30-2015, 06:31 PM
On the audio track you are recording to, have you set the right input from the interface and made sure the rec button is set to record?
And what did you mean by D Mode?
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-30-2015, 06:37 PM
How experienced with Pro Tools are you?
What are you trying to record? With what model mic etc. how is that connected to the interface with what cable.
I think that interface has hardware monitoring so just hearing stuff in your headphones does not mean that signal is coming though Pro Tools.
What meters are you talkign about? The track meters in Pro Tools.
Does playback work at all? Create an empty session with a stereo audio track. Drag your favorite mp3 or similar onto that track. Do you see the waveform appear? Press play on the transport. Do you hear that track play? if not you have a problem here you have to solve first.
If you are tryign to record vocals or say audio from a guitar or bass you must create a mono *audio* track (not an instrument track).
The track is record armed correct? (red light on) and your transport is in record mode.
Start by workign with as simple as possible test session. i.e. An empty session with use one mono audio track, no master fader, nothign else.
Post screen shots of your play back engine dialog panel.
The IO>Setup input, output and bus panels
and your Mix widows clearly showing the input and output IO assignments.
Old 09-30-2015, 07:00 PM
Southside:
I'm admittedly not that experience (long time with SE that's about it).
I figured it out. I think PT was still mapped to another interface. So I closed out, shutdown, and when I restarted PT I held down "N" like you said and it recognized the Fast Track 8R.
Thanks so much for your help. I really appreciate it.
Regards,
Wayfarer92
Old 10-01-2015, 04:51 AM
Southside:
Regards,
Wayfarer92
Great news
Thanks for posting that!
We are here if you need any further help now or in the future.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
Ableton/Logic w/ MBox2 - Record Arm Audio Track and I see signal level andygatr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2010 07:10 AM
M-Audio 1010 Signal Stutter record and playback issue tmoc-rocks Pro Tools M-Powered (Win) 1 09-01-2009 03:14 PM
Record-Enabled Audio signal silent during playback trevlino Digidesign Hardware & Software 3 04-06-2006 02:52 PM
How to record audio signal through SampleTank? Digitalkidd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-10-2004 06:58 PM
