Old 04-28-2012, 06:05 PM
stpete111 stpete111 is offline
Default Keyboard Shortcut to tab cursor to next grid line?
Hi All,
How do I simply advance my cursor gridline-by-gridline in a particular track in the Edit window? I can only see how to either tab to transients or tab to beginning or end of a clip/region. Seems like being able to tab to gridline within a track would be simple, but the Shortcuts guide doesn't like any ability to do it. Anyone know how?
Old 04-28-2012, 06:41 PM
Default Re: Keyboard Shortcut to tab cursor to next grid line?
Just figured out that holding Command while pressing the Fast Forward button on the Transport Window tabs by however many measures at a time that you set it for in Preferences. That's one step closer for me, but I was looking for a keyboard shortcut that does not require any mouse use at all...
Old 04-28-2012, 07:07 PM
Stig Eliassen's Avatar
1 and 2 (numpad) will move the cursor 1 bar back and forth. Multiple hits will move it multiple bars.
Old 04-28-2012, 07:21 PM
Hello Stig,
Thanks for the reply. I'm on a laptop so I lack the number pad. However, due to this shortcut, and many more that I can't perform b/c I lack the numpad, I am going to go ahead and get a USB keyboard with a numpad. It'll be worth the purchase for sure.
Thanks.
Old 04-29-2012, 12:52 AM
Vovique Vovique is offline
Another workaround: you can nudge selections, so as long as you select something, you can nudge it to the grid. For pasting audio, for example, selection start equals cursor, so this will work in most cases.
Old 04-29-2012, 11:30 AM
Vovique, doesn't nudge actually move regions though? I want to navigate the grid w/o actually moving anything...
Old 05-01-2012, 09:57 AM
The Weed's Avatar
The Weed The Weed is offline
If you have not highlighted an area or region, nudge will move the cursor by the set value.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-01-2012, 10:01 AM
Dizzi45Z Dizzi45Z is offline
Originally Posted by stpete111 View Post
Hello Stig,
Thanks.
Does anybody know if the use of a USB keypad will link together with the other controls on the Laptop? For example, could you press "Command - 1 (on the number pad)" and get the correct results? I tried this with a Blue Tooth Keyboard and the OS (snow leopard) sees the two keyboards as completely separate keyboards, so key combinations like that won't work.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 05-01-2012, 02:00 PM
Audioartist Audioartist is offline
Default
Shortcut combinations does not work with my targus usb keypad.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 05-01-2012, 03:20 PM
Cheers,
Thanks Weed, I think this is going to be the best answer for me.
Keyboard shortcut to highlight until next grid the hecksome Pro Tools 10 1 11-08-2012 09:19 AM
Cursor + Grid +TC = playback issue Guy McDude Pro Tools TDM Systems (Mac) 1 03-28-2011 03:02 AM
Keyboard shortcut triplet grid 24bit dither Pro Tools TDM Systems (Mac) 1 11-17-2009 01:54 AM
grid/cursor problems mfym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-14-2004 10:22 PM
Quick Grid/Cursor question in 6.1...... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-12-2003 08:06 PM
