Old 12-29-2010, 07:19 PM
Ro Cho Ro Cho is offline
Default "Audio Device Buffer Underflowed" Constant Error!
I've reached the peak of frustration with Avid and Pro Tools..
No matter how many tracks or what session I have open, during recording or playback I will constantly get the 6065 error 'Audio Device Buffer Underflowed' Error.
I have tried everything possible!.. I have reduced and increased the H/W Buffer Size, Restarted Pro Tools, Restarted my PC, Re-installed Pro Tools.. to no success. (Pro Tools is running in administrator mode)
My system specifications are listed below..
I would greatly appreciate your help!..
Thank You
Asus N71JQ
4GB Ram
Windows 7 Professional 64bit
Mbox 2
Pro Tools 9
OCZ Vertex 120GB SSD Drive (System Drive)
Western Digital 640GB 5400RPM (Pro Tools Drive) in an E-SATA Dock
Old 12-29-2010, 08:13 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: "Audio Device Buffer Underflowed" Constant Error!
This is a problem - you need a minimum of 7200 RPM hard drive.
Here's some info that might help:
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive.
Pro Tools supports recording and playback to a secondary drive that meets the following requirements:
7200 rpm or faster
9ms seek time or faster
Firewire drives must have the Oxford 911 (FW400 port), Oxford 912 (FW400 & FW800 ports) or Oxford 924 (FW800 ports) Bridge chip. USB drives are not supported and are known to be problematic. Here are some useful links to determine if the drive you have, or are considering, has the proper chipset:
Chipsets used in Maxtor external drives
Chipsets used in Seagate external drives
Pro Tools FireWire Drive Requirements on Windows Systems
Pro Tools EIDE/ATA Hard Drive Requirements on Windows Systems
Pro Tools SATA Hard Drive Requirements on Windows Systems
Pro Tools SCSI Hard Drive Requirements on Windows Systems
And make sure you do this:
Note: To enable other users to help you, please include all of your system details when posting an issue to the DUC; Pro Tools hardware, Pro Tools software version, CPU, OS version, Motherboard make/model, chipset, amount of RAM, type of hard drives used, etc.
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-29-2010, 09:55 PM
Hey,
Thank you for the reply :)..
I realised this and I replaced the 5400RPM dirve with a Seagate 1TB 7200RPM drive, but I am still getting the same error and now my audio will just go silent midway through playback before the error occurs in some cases.
My Detailed System Specs are below
Really appreciate your help! :)
SiSoftware Sandra
Computer
Model : Asus N71Jq
Workgroup : WORKGROUP
Host Name : RogerW
User : Roger W
Processor
Model : Intel(R) Core(TM) i7 CPU Q 720 @ 1.60GHz
Speed : 1.73GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 2 Unit(s)
Type : Mobile, Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
L3 On-board Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : Asus N71Jq
BIOS : AMI N71Jq.204 12/24/2009
Bus(es) : PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DDR3 SO-DIMM
Chipset
Model : ASUS Core (Clarksfield/Lynnfield) DMI
Front Side Bus Speed : 2x 2.4GHz (4.79GHz)
Chipset
Model : Intel Core Mobile (Clarksfield) UnCore
Front Side Bus Speed : 2x 2.13GHz (4.26GHz)
Channels : 2
Memory Bus Speed : 2x 665MHz (1.33GHz)
Memory Module(s)
Memory Module : Kingston ASU1333D3S9DR82G 2GB DDR3 SO-DIMM PC3-10700S DDR3-1334 (9-9-9-25 4-34-10-5)
Video System
Video Adapter : ATI Mobility Radeon HD 5730 (400 SM5.0 650MHz, 1GB DDR3 2x800MHz, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : ATI Mobility Radeon HD 5730 (400SP 650MHz, 1GB DDR3 2x800MHz)
STREAM Processor : ATI Mobility Radeon HD 5730 (400SP 5C 650MHz, 1GB DDR3 2x800MHz)
Storage Devices
OCZ-VERTEX2 (120GB, SATA300, SSD, NCQ) : 112GB (C:)
Seagate ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (E:)
HL-DT-STBDDVDRW CT21N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache, 192kB Flash) : N/A (D:)
XKXSZG 52BK52F49A (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (G:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (E:) : 932GB (NTFS) @ Seagate ST31000340AS (1TB, SATA300, 3.5", 7200rpm, NCQ)
Hard Disk (C:) : 112GB (NTFS) @ OCZ-VERTEX2 (120GB, SATA300, SSD, NCQ)
Optical Drive (D:) : N/A @ HL-DT-STBDDVDRW CT21N (SATA150, BD-R, DVD+-RW, CD-RW, 2MB Cache, 192kB Flash)
Optical Drive (G:) : N/A @ XKXSZG 52BK52F49A (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
Peripherals
LPC Hub Controller 1 : ASUS HM55 LPC Interface Controller
Audio Device : ASUS P55/PM55/3400 High Definition Audio
Audio Codec : Realtek Semiconductor High Definition Audio
Audio Device : ASUS Redwood HDMI Audio [Radeon HD 5600 Series]
Disk Controller : ASUS P55/PM55/3400 4 port SATA AHCI Controller
USB Controller 1 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 2 : ASUS P55/PM55/3400 USB2 Enhanced Host Controller
USB Controller 3 : ASUS uPD720200 USB 3.0 Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : CutePDF Writer (4000x4000, Colour)
Printer : Canon MP630 series Printer (USB, Colour)
Network Services
Network Adapter : Atheros AR8131 PCI-E Gigabit Ethernet Controller (Ethernet, 1Gbps)
Network Adapter : Bluetooth Device (Personal Area Network)
Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 97%
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 5.9
Old 12-30-2010, 03:25 PM
DRC Music's Avatar
DRC Music DRC Music is offline
Is your new Seagate 7200rpm drive USB?
Pro Tools Ultimate 2023.6
Logic Pro 10.7.8
macOS Ventura 13.3
MacBook Pro (16-inch, 2021)
Apple M1 Max
Memory 64 GB
PreSonus Quantum 26x32 Thunderbolt
Old 12-30-2010, 06:53 PM
djgizmo djgizmo is offline
Default
Drc,
If you re-read the last sentence, he gives you the answer.
Old 12-30-2010, 08:59 PM
DRC Music's Avatar
Ahhh... The last line of his sig... my bad >.<
Logic Pro 10.7.8
macOS Ventura 13.3
Apple M1 Max
Memory 64 GB
Old 12-30-2010, 09:11 PM
Both these must be disabled when running Pro Tools
Old 12-31-2010, 09:23 PM
Thank you for all your replies!
After disabling my wireless and bluetooth adaptors on my notebook, I still got the error on one particular session. Other sessions seem to be fine though, so it could just sum up to a corrupt session.
Thank you for all your help!
Appreciate it..
Old 01-02-2011, 09:12 AM
critza critza is offline
Appreciate it..
Try importing the tracks from your corrupt session to a new session with import session data. Import them one by one and try playing the session. Often there is one particular track that is corrupted and the others are fine.
Good luck
/christer
PC 7980XE @ 4.2
PT 12.7 Ableton 10.0.1
Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650
IS Pro Double 6" Speakers, www.intelligentsound.se/
Recording to a new External Harddrive, now "audio device buffer underflowed" MSCHAAF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-24-2011 06:07 PM
Error at startup: "Your audio device is configured with an unsupported buffer..." Kronos78 Windows 0 05-03-2011 01:39 PM
"Audio device buffer underflowed..." Help rid me of this buffer error Jim Digby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-07-2011 09:29 PM
"the audio device buffer underflowed"... james21789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 08-13-2009 06:48 AM
Mbox 2 Pro "audio device underflowed" error 6085 blu2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-29-2009 04:27 PM
