Mbox 2 disappeared
My Mbox disappeared, having me a "found new hardware" message, probably because of a virus from wich i got rid of. I have tried to reinstall only the mbox's driver but it did not work. Then I tried to uninstall everything about pro tools, including plug ins and demos. Did not work. I then came here and I found this thread: http://duc.digidesign.com/showthread.php?t=227954 But it unfortunately did not help as the conversation came into system configuration. My Mbox was working properly but yesterday morning, it began not working. My firewire cable is okay, as my led is blinking. I just can't install the mbox. Can you help me? Thanks. |
Re: Mbox 2 disappeared
When you say 'did not work' - can you explain a bit more clearly? Did the uninstall not work?
You may want to visit the General Troubleshooting thread, as it has suggestions that may help (like using the PT Uninstall utility). You should also post your Sandra report if you're unable to resolve the issue. |
Ok... I tried reformatting my computer and I still did not have success getting my mbox recognized by windows neither by pro tools.
I clicked on the link you gave me but i did not find how we make a sandra report. I can say that my computer's specs are: Windows XP Pro SP3 AMD Sampron 2400+ 1.67 Ghz 768 Mb Ram Mbox 2 pro connected to a NEC OHCI Compliant IEEE 1394 Host controller I hope this is enough. What happens: I follow the steps as indicated in my Getting Started Guide: I disconnect mbox. I run the setup wizard located in Pro Tools LE Setup folder on the cd. I install Pro tools in C:/Program Files When I'm asked to connect the mbox, I do. Then the setup continues and the mbox's LED is blinking orange. When the setup's done, I take out the cd before rebootiing. After reboot,the mbox' led is still blinking. I try to open Pro Tools and it says that it cannot find any hardware connected although the led is blinking. The I tried many times to uninstall pro tools and all of his components and drivers and retry these steps, without any success. Note: I am not prompted that a new hardware has benn connected when I plug the firewire cable in his slot. Also, there is a mbox in my device manager list with a yellow question mark. I have tried before reformatting to install the driver directly from that list but it did not work either. Now, what do i do??? Thanks. Sorry for my bad english. I am from french speaking canada... |
I also want to say that it WAS functionning before last sunday and that it stopped without any evident reason.
Note: To enable other users to help you, please include all of your system details when posting an issue to the DUC; Pro Tools hardware, Pro Tools software version, CPU, OS version, Motherboard make/model, chipset, amount of RAM, type of hard drives used, etc. - Please - Use SiSoftware's Sandra Lite application to generate a full system profile: www.sisoftware.co.uk Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC. Quote:
Ok, I will get another processor. But am I wrong or the problem I have seems to be from a driver issue? Will the fact that I change processor resolve my driver problem?
Meanwhile I find another motherboard/processor, can we go on finding the problem? Here is my sandra report: SiSoftware Sandra Processor Model : AMD Sempron(tm) 2400+ Speed : 1.67GHz Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB, Synchronous, Write-Back, 2-way, 64 byte line size L2 On-board Cache : 256kB, ECC, Synchronous, Write-Back, 16-way, 64 byte line size System Mainboard : GIGATREND Technology Co., Ltd. XP-K7V400 Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software International, Inc. F3 Total Memory : 768MB DDR Chipset Model : Giga-Byte VT8377 Apollo KT400/A/600 CPU to PCI Bridge Front Side Bus Speed : 2x 167MHz (334MHz) Total Memory : 768MB DDR Memory Bus Speed : 2x 167MHz (334MHz) Memory Module(s) Memory Module : OCZ OCZ400512V25 512MB DDR PC3200U DDR-200 (2.5-4-4-8 2-12-0-0) Memory Module : SpecTek 256MB DDR PC2700U DDR-166 (2.5-3-3-7 2-10-0-0) Video System Adapter : NVIDIA RIVA TNT2 Model 64/Model 64 Pro (Microsoft Corporation) (AGP 2.00) Storage Devices WDC WD1200JB-00GVA0 120GB (ATA100, 3.5", 7200rpm, 8MB Cache) : 112GB (C:) (F:) SAMSUNG SV1204H 120GB (ATA100, 3.5", 7200rpm, 2MB Cache) : 112GB (D:) ST3500830AS 1TB (USB, 3.5") : 932GB (E:) PIONEER DVD-RW DVR-112D (ATA33, DVD+-RW, CD-RW, 64kB Cache) : N/A (G:) Logical Storage Devices Hard Disk (C:) : 20GB (FAT32) @ WDC WD1200JB-00GVA0 120GB (ATA100, 3.5", 7200rpm, 8MB Cache) DOCS (F:) : 92GB (NTFS) @ WDC WD1200JB-00GVA0 120GB (ATA100, 3.5", 7200rpm, 8MB Cache) Chantal (D:) : 112GB (NTFS) @ SAMSUNG SV1204H 120GB (ATA100, 3.5", 7200rpm, 2MB Cache) CD-ROM/DVD (G:) : N/A @ PIONEER DVD-RW DVR-112D (ATA33, DVD+-RW, CD-RW, 64kB Cache) 3.5" 1.44MB (A:) : N/A EXTERNE (E:) : 931GB (FAT32) @ ST3500830AS 1TB (USB, 3.5") Peripherals LPC Hub Controller 1 : Giga-Byte VT8235 PCI to ISA Bridge Audio Device : VIA M Audio Delta-44 Audio Device : Giga-Byte GA-7VAX Onboard Audio (Realtek ALC650) Audio Codec : Gammagraphx 0000h Audio Codec : Gammagraphx 0000h Serial Port(s) : 3 Parallel Port(s) : 1 Disk Controller : Giga-Byte VT82xxxx EIDE Controller (All VIA Chipsets) USB Controller 1 : Giga-Byte VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 2 : Giga-Byte VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 3 : Giga-Byte VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets) USB Controller 4 : Giga-Byte VT6202/12 USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr System SMBus Controller 1 : VIA VT823x SMBus Printers and Faxes Printer : Lexmark X5100 Series (600x600, USB, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Scanners and Cameras Scanner : Lexmark X5100 Series (USB) Network Services Network Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 3) Platform Compliance : x86 Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Ok. Thanks.
After 6 months being kept in a box, my sweet little mbox is ready to be hooked up to my brand new computer. Nothing else has been installed on it and I still have the same f*ng problem!!!!!!!!! I just bought version 8 just because that new PC is on vista... Now tell me what's wrong with my hardware, please!!! Her is my sandra report: SiSoftware Sandra System Model : Compaq-Presario FQ630AA-A2L SR5718F Workgroup : WORKGROUP Host Name : PC-de-Mathieu User : Mathieu Processor Model : Intel(R) Pentium(R) Dual CPU E2220 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 1MB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 threads sharing System Mainboard : MSI Boston BIOS : Phoenix Technologies, LTD 5.17 (01/15/2009) Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR2 Chipset Model : HP P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 3GB DIMM DDR2 Shared Memory : 8MB Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Samsung M3 78T5663QZ3-CF7 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Samsung M3 78T2863QZS-CF7 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Adapter : Intel(R) G33/G31 Express Chipset Family (8 SP, PCI) Storage Devices Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) : 233GB (C:) (D:) ST3500830AS (500.1GB, SATA300, 3.5", NCQ, 8MB Cache) : 466GB (E:) HP Officejet 6310 (USB) : N/A (G:) TSSTcorp CDDVDW TS-H653Z (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices COMPAQ (C:) : 222GB (NTFS) @ Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) FACTORY_IMAGE (D:) : 11GB (NTFS) @ Hitachi HDP725025GLA380 (250GB, SATA300, 3.5", 7200rpm, NCQ, 7MB Cache) Hard Disk (E:) : 466GB (NTFS) @ ST3500830AS (500.1GB, SATA300, 3.5", NCQ, 8MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW TS-H653Z (SATA150, DVD+-RW, CD-RW, 2MB Cache) Removable Drive (G:) : N/A @ HP Officejet 6310 (USB) Peripherals LPC Hub Controller 1 : HP 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : Fintek F71882FG/F71883FG Audio Device : HP 82801G (ICH7) High Definition Audio Audio Codec : Realtek Semiconductor Realtek 662 High Definition Audio Disk Controller : HP 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : HP 82801G (ICH7) USB Universal Host Controller USB Controller 2 : HP 82801G (ICH7) USB Universal Host Controller USB Controller 3 : HP 82801G (ICH7) USB Universal Host Controller USB Controller 4 : HP 82801G (ICH7) USB Universal Host Controller USB Controller 5 : HP 82801G (ICH7) USB 2.0 Enhanced Host Controller FireWire/1394 Controller 1 : NEC uPD72874 IEEE1394 OHCI 1.1 3-port PHY-Link Ctrlr SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Officejet 6300 series fax (200x200, USB, Colour) Printer : HP Officejet 6300 series (1200x1200, USB, Colour) Scanners and Cameras Scanner : HP Officejet 6300 (USB) Digital Camera : Officejet 6310 (USB) Network Services Network Adapter : Realtek RTL8101E Family PCI-E Fast Ethernet NIC (NDIS 6.0) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Home 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 3.2 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
MBox External Disappeared | bluestudio | FireWire & USB Audio Interfaces (Win) | 8 | 05-30-2013 08:38 AM |
HD on Mac disappeared | stevegalante | Storage Subsystems | 10 | 08-17-2012 01:51 AM |
Mbox 3 disappeared from playback engines | LaS | Windows | 0 | 05-10-2012 04:15 PM |
Help: My 192 has disappeared! | alanbuf | macOS | 1 | 01-03-2012 04:51 PM |
Mbox 2 disappeared.... | aandina | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-08-2007 10:53 PM |
