Old 10-10-2007, 07:08 AM
pakobo7 pakobo7 is offline
Default Re: Creating Crossfades between regions
Shan, I tried your technique, but I'm still getting an immediate cut-off between region 1 and 2. It looks like the picture you referenced also has an immediate cut-off, instead of actually fading into one another.
Isn't there a way to get the wav from region 1 to continue past the splice point, and the wav from region 2 to start before the splice point?
Old 10-10-2007, 08:11 AM
dillon99999 dillon99999 is offline
as an alternative, you can:
1. move the audio files onto separate tracks.
2. use volume automation to fade out the first track.
3. use volume automation to fade in the second track.
Old 10-10-2007, 08:24 AM
Dillon999, that's a good idea, I actually considered that, but then the bummer of it is then I have to mess with 2 separate tracks for one audio input. Do you have any idea how to get those wav files to blend into each other rather than cut out at the splice?
Old 10-10-2007, 12:57 PM
nope.
Old 10-10-2007, 07:23 PM
dillon, thanks for the help, I appreciate the response even if we're still stuck. So when you make crossfades, do you just work with an abrupt splice?
  #16
  #17
Old 10-11-2007, 07:47 AM
you said: "the bummer of it is then I have to mess with 2 separate tracks for one audio input"
i use all 32 tracks.
i separate everything out.
if everything is separated out, then you don't need to do many crossfades - you can simply trim regions down.
your system should be able to RECORD ALL 32 TRACKS SIMULTANEOUSLY.
so what is the big deal with regards to having a single input going to several tracks and recording to them?
not sure what the issue is - i think you are making it harder on yourself than it has to be.
use it like a tape recorder - have you ever worked on an Otari 2-inch 32-track tape machine?
you can't do a "cross fade" on one of those.
i think too many new engineers out there are lost in technology land.
i am from a generation of engineers that is almost extinct now.
while i embrace technology and what it has to offer, i never lost sight of what was important:
avoid making things more complicated than they need to be and keep it simple.
  #18
Old 10-11-2007, 10:16 AM
Dillon, again, thanks for the input, and I definitely am a fan of keeping things simple (since I don't know enough about the tech make it complex).
I do RECORD to multiple tracks simultaneously, but as for mixing and editing, I thought it would be less simple to have to adjust levels on multiple tracks for the same guitar part. You're right, in older times, I wouldn't have the luxury of crossfading between different takes to get the best possible region, but since it is possible, I'm just trying to figure out how to do it properly.
I suppose I could do those 2 tracks and then bus them both to an Aux track...i just can't help feeling that doing that I'm missing out on the whole benefit of crossfading if I do that...
  #19
Old 10-11-2007, 11:01 AM
don't forget that you can also apply volume automation to the aux / bus track.
so in addition to the audio track's volume automation, you can have aux track volume automation, which helps to smooth out transitions even further.
also try to apply some reverb to the aux track, to help make the audible transition less apparent.
  #20
Old 10-11-2007, 05:34 PM
Shan's Avatar
Shan Shan is offline
I dont understand what you mean by "cutoff"? My screen capture examples actually fade into each other. Dont forget that you have to have data to fade into.
Give me 10-15 min and I'll post another example that should clear this up for you.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Creating crossfades across multiple tracks edwar64896 Pro Tools 10 1 10-11-2013 08:04 AM
Beat Detective very slow creating crossfades gonzolagonda Pro Tools TDM Systems (Mac) 1 09-21-2009 06:31 AM
Moving regions with crossfades Trazan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2009 10:51 AM
Creating Effective Crossfades pakobo7 Tips & Tricks 7 10-24-2007 04:45 PM
Having trouble creating Crossfades between regions popedcollarpro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-16-2007 11:34 AM
