Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 12-12-2019, 02:39 AM
globaleric globaleric is offline
Default Avid Control v19.12- Mixer View: Function View Question
Just upgraded EuControl and the iOS Control app yesterday after finishing a project.
Everything appears to work fine so far, except for that Function View area on top of the channel strips:
It's always looking *empty", like in the upper screenshot on page 15 of the Avid Control Guide document. Tapping that area doesn't change anything, so no cycling between EQ, Dynamics, etc. as described in the manual.
=> Am I missing something, e.g. is this Function Area only supported by specific (digidesign?) plugins which I'm usually not using?
Also, is there some trick for clearing/resetting channel peak levels via the app?
Simply tapping the peak value doesn't appear to work.
BTW this 19.12 version appears to be much more reliable again on my setup regarding the initial EuCon/PT connection than the previous 19.9 version, which always required several attempts including killing the iOS app.
Just EuControl still takes "forever" to load (icon finally appears on the MacOS menu bar) after a system boot.
TIA for any hints
Mac Mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD
Mojave 10.14.6, PT 2019.12, Waves and Massey plugins
Presonus Quantum, MC Transport, Avid Control, Tascam HS-P82 Field Recorder
[Questions] Solo all routed channels in one click, mixer view follows edit view Eytan3000 Pro Tools | First Discussion 1 10-02-2017 03:30 PM
How can I keep my mixer view in view? Sam C macOS 14 05-16-2013 03:16 PM
function keys to view EQ or plug-ins? Adam C VENUE Live Sound Systems 3 07-04-2012 05:07 PM
Quick key for changing edit view to volume view in track? postman56 Pro Tools TDM Systems (Mac) 4 11-30-2007 11:56 AM
View Audio Automation Midi View change TommyT Pro Tools TDM Systems (Mac) 0 01-04-2007 01:18 PM
