Old 12-16-2013, 11:30 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: EUCON/EuControl 3.1 available
The hidden track functionality will be an amazing help with layouts (CFG)! Thanks for the hard work and the notification.
-Ryan Young
•Pro Tools 12.6 (x2)
•OSX 10.11 & 10.12
•Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon (x2)
•16 GB 1333 MHz DDR3 (x2)
•HD Native PCIe (x2)
•HD Omni (x2)
•192 i/o
•96 i/o
•4 Seagate Barracuda 1.5TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
•Blackmagic Intensity Pro (HDMI)
Old 12-17-2013, 06:09 AM
eesn eesn is offline
Originally Posted by JC Haydon View Post
EuControl 3.1
just to double-check and confirm: is this compatible with Pro Tools 10?
Old 12-23-2013, 07:43 PM
amuntner amuntner is offline
Reporting an issue after upgrading Eucon from 3.0.1 to 3.1 on Win 7 64 bit and upgrading the firmware on my Artist Mix:
After upgrading from 3.01 to 3.1, and upgrading the firmware on the Artist Mix, Ableton Live would no longer see the virtual midi ports. Downgrading back to 3.01/1.5.1 firmware didn't work, either.
Workaround:
In Windows Device Manager, Euphonix Virtual Midi and Avid Virtual Keyboard Device both displayed errors saying that their drivers weren't properly signed. An exclamation point icon in a yellow triangle was next to each device.
The solution was to press and hold 'F8' during restart once Windows starts to load. Then, select "Disable Driver Signature Enforcement from the boot menu."
Avid, could you please release another version with signed drivers? The workaround has security implications.
Old 12-25-2013, 02:16 AM
ALSTUDIOS ALSTUDIOS is offline
Originally Posted by kdarbyshirebryant View Post
Some correctly signed drivers would help a great deal and reduce confusion on the Windows platform.
+1, issue confirmed
ALSTUDIOS REGENSDORF SWITZERLAND
a.l.recordingstudio.ch@gmail.com
https://sites.google.com/site/alrecordingstudio/
1pc AVID Artist Control and 1pc Euphonix MC Mix
Win7 64Bit, Cubase Pro 10.0.20
Old 12-29-2013, 03:02 AM
My workaround is as follows
Hi
Tried and failed completely
It was same mess as before
I'm now back on 2.7.1 and the related FW Versions of the devices.
Waiting for an updated (working) AVID Driver.
But....thanks for your Information.
Cheers
  #16
Old 12-30-2013, 11:44 AM
bassmagnetic bassmagnetic is offline
same here, exclamation marks for Avid Virtual Keyboard Device and Virtual midi drivers...
I mean, really, have they ever heard of beta testing? How can a supposedly 'professional' company release drivers so poorly checked?
  #17
Old 01-01-2014, 09:16 AM
This worked for me on 64 bit Windows 7. Thanks!
My workaround is as follows...
{snip}
You should now have EUControl 3.1 installed but with working virtual keyboard & MIDI drivers.
I've also found that if it's not at first found as a MackieControl device by your DAW (in my case, Live), try:
- Open the Task Manager, make sure EuControl.exe is running. If not, start it.
- Going to Control Panel -> Eucon and in the dialog box reset the channels from, say, 1-4 to 5-8, and then back, clicking through "OK" when it says you need to reboot each time. (you don't really need to, don't worry)
  #18
Old 01-14-2014, 07:32 AM
supersonic1000 supersonic1000 is offline
My setup crashes the Midi Server all the time. I am running Mavericks.
MBP 17", PT 10 CPTK, DP8, Apollo, Traveller, Ultralite, UAD-Quad, most of the UAD plug-ins, Waves Gold, Virtual Instruments, Nord Piano, Korg CX-3, Mics - Telefunken, Beesneez, AKG, Sennheiser, Shure, EV, Sontronics, Pres - Imbir, UA, Sebatron, Analog Addicts UK, 4-710. Monitors - APS Trinity, Aeon, Coax, Sub 15
www.aps-company.pl
  #19
Old 01-15-2014, 05:20 AM
Jabu Jabu is offline
Hi
I have a problem, my iMac ethernet port got damaged. I bought an apple (ethernet to thunderbolt) adapter, will it work and I have been having problem setting up my artist mix (mixer) with my FCP 7, I need to mix work but cant link the two need assistance asap.
Kind regards
Jabu
  #20
Old 01-15-2014, 05:50 AM
Hi
Kind regards
Jabu
EUCON/EuControl 3.1 Now Available Artist PM Technical Alerts 0 12-13-2013 07:11 PM
Updated Eucontrol to 2.7 and upgraded to Mountain Lion 10.8.2. Eucon now broken. Focuret macOS 0 03-08-2013 10:21 PM
No Eucon commands visible in Eucontrol software 2.6.2 (Win7 64bit, PT 9.0.5) Elmobe Artist Series 0 11-23-2011 03:35 AM
EUCON 2_6_1 eucon discovery cant find ip klaukholm System 5 2 10-22-2011 01:01 PM
