Re: All Artist Mix won't power on users...come on in.
There is something I am wondering about...
I found this in the Artist Series Support page: My Artist Series Controller doesn't power up, OR I'm experiencing intermittent power with my Artist Series Controllers? Quote:
What if the IEC plug starts working it's way out of the socket and gets to the point where it is barely making contact with the pins in the PSU receptacle. With any vibration (maybe from speakers) you could get to a point where you would get arcing across the contacts...this could definitely be the cause of the ferrite at the PSU entry point to die. Since the PSU itself is small and has very little mass compared to the IEC cable and it is only a 'friction fit', this could most definitely be the cause. I'm going to 'tie wrap' my IEC cable to the PSU for now, and see if it happens again. Note to those who've had this failure, or are just experiencing it now, if you checked the power plug did it seem 'loose' or not fully inserted into the socket? robertg may be correct...sort of.
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
I've had one Artist control fail on me in this way and Avid was great in replacing it. However, the fact that this seems to be a general fatal flaw with this equipment and my warranty period is almost over, I have very little confidence in this unit and will not be making any long term plans with it in my workflow. It just seems destined to fail like the last one. Pretty sad.
I don't suppose anyone has had any luck with the part/component number of the L7 and L8 inductors? Mine just went out, and I'm out of warranty.
Thanks |
#16
I'm going to look into a reverse engineering, sort of, on this. As we already know the specs...they are on the PSU, voltage and current...my 'educated' guess is these are used to shunt hi-freq emi from spitting out of the PSU port and causing the unit to fail EMI compliance. Most of those types of ferrites are rated at ohms @ 100mhz. In this instance I think finding a ferrite that has the current and voltage capacity (current being the major spec to meet), and physical size. I would think that if you'd want to take a chance, you could bridge the pads and live without EMI protection...except if the condition that is causing them to physically fail manifestes to a greater degree upstream you may have bigger issues... I 'think' the problem is arcing of the power, neutral, and/or the ground of the IEC female to male in the PSU connector due to it 'walking' it's way out slightly over time, possibly from speaker vibration...then again you could put a fuse in place at the PSU rating...
#17
Well, I think I've found the part. It's a Laird CM3312R111R-10. It's a an SMD common mode choke chip. It's a very unique package. I looked at over 2000 pictures of other components and this is the ONLY part with the footprint and terminal layout.
HOWEVER...according to Digi-Key the part is obsolete and they have none in stock and can't get any more. I haven't checked other distributors. I took the cover off my mix to verify the part and found something I didn't expect. There was a new and different part in place of L7 and L8. They were bigger and appear more robust and there was a bit of trace rework. This can mean one of 2 things. 1: The part that was in there originally was indeed the Laird part and it is indeed obsolete and AVID had to substitute the parts in there just to get it to work again. 2: what was said in #1 above AND these parts and the rework was done to address the issue many have been having with the Mix and this was part of an ECO. If 2 is the case, anyone sending the unit back for repair should have a more reliable Mix in the future. I'm keeping my router earthed and my Mix PSU IEC plug lashed to the PSU anyway. Hope this helps.
#18
Did you get a picture of the rework and I just missed the link? |
#19
I didn't as it probably wouldn't have helped. There was a fair amount of what looked like short sections of wire-wrap doing bridges and some of the rework was hidden under the new parts. IIRC.
#20
I'm going insane here. Bought an Artist Mix and Control last year from a store in the States and had them shipped overseas where I currently am.
Last year the Artist Mix blew while I was working. Right where the power supply connects. After a bunch of back and forth they finally connected me to someone in Beijing that could help me. They ended up sending me a brand new Mix. So I was a happy camper until a few days ago, as I'm freaking sitting here, the god damn Control blows. wtf! Are these things made to only be used for a certain amount of time until they blow up? I think my warranty is over and I'm all the way in China. Does anyone have any advice at all for me? Are there some parts I can order and do a self-repair? This is beyond messed up...
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix | Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone |
Artist Series and Power Mac G5 | TGlee | Artist Series | 0 | 06-29-2013 06:42 AM |
Artist and Control 24 users with experience. Comparisons please | P,B,S | Artist Series | 3 | 05-05-2013 07:37 AM |
So I wonder if PT11 will add for Artist users | smfelton | Artist Series | 5 | 04-10-2013 10:57 AM |
Unleash the power of our Artist Series, sysex, Mackie and MIDI | RaToX | Artist Series | 0 | 03-31-2011 03:28 PM |
Systems for NON-Power users? | orchard69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-07-2008 05:47 PM |
