Old 03-26-2013, 06:57 PM
www www is offline
Default White Noise on Playback!
Odd one here. Imported an .omf into Pro Tools 9.0.2 on a Mac running 10.6.4. Waveforms look fine but when play is pressed all we hear is loud white noise out the output of the laptop. Other sessions playback fine however. The .omf even opens up and plays alright on a different Mac. (running 8.04 HD) We can pull a random audio file from a drive into a track into the PT 9 session and it will play OK. Just the audio from the .omf won't play. Even if a clip from the .omf is pulled onto the track that plays the random audio file alright, the clip will just output noise.
Checked the aggregate and it appears to be in order. The speaker icon is next to the "Built in output" however not in the aggregate's "Built in Output". Is this normal? I mean the microphone icon for input show up in the aggregate.
Ideas appreciated!
Old 03-27-2013, 06:16 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: White Noise on Playback!
Ideas appreciated!
Is the session at the same frequency and bit rate as the OMF file?
Are you using conversion when importing the OMF data?
This is what i would be checking! the frequency and bit rate.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-27-2013, 08:43 AM
www www is offline
Yes the .omf and the session are both 48k 24 bit.
One other detail I forgot to add. When I opened the session in PT 8.0.1 successfully, I then copied it to another drive and tried to open it on the laptop running PT 9 and got the same results as opening the .omf directly in PT. Noise! Strange!
Thanks for your help!
Old 03-27-2013, 05:51 PM
www www is offline
We may be on to a solution. So far "Consolidate Media on Import" seemed to be working and then it stopped. Still looking for an answer.
Old 03-27-2013, 11:40 PM
www www is offline
The problem was with the hard drive the .omf originally came to us on. Once transferred to another drive they opened up as expected.
Thanks for you suggestions though!
[IMG] code is Off
White Noise during Playback nyc.editor macOS 14 02-12-2013 11:47 AM
White noise on playback = why is this? bahamaha Pro Tools M-Powered (Mac) 1 01-01-2013 09:27 PM
White noise during playback xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2012 05:54 PM
Static noise (aka White noise ) During playback. =/ PoPimp3069 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 03-23-2010 05:06 PM
white noise during playback thyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-20-2009 11:07 AM
