Old 06-21-2010, 12:23 PM
thienbanguyen thienbanguyen is offline
Default Transpose or changing key for the whole song
Is there anyway to change the key for the whole song for example from C to D? I can see Transpose feature but I won't able to click on "Apply" to make a change. Am I missing something? I recorded a sample track as audio track. Appreciate any help!
Old 06-21-2010, 12:48 PM
Chase743 Chase743 is offline
Default Re: Transpose or changing key for the whole song
You can definitely do this in Audio Suite. I just forget the exact option. Take a look there and give it a shot.
Just a note - I wouldn't recommend this for anything other than a demo. There definitely will be some quality degradation.
Once, I had to learn a popular song in another key, so I actually imported it into Pro Tools, and used this feature to transpose it. Didn't sound great, but it made practicing it a lot easier.
PC: Dell Studio XPS 9000
Hardware: 002r, Mbox 2, Digimax D8, ART Pro MPA II (w/ Mullard Tubes)
Guitarist | Singer | Songwriter | Engineer
www.stolenalibi.com
Old 06-21-2010, 01:10 PM
Thanks for the info. I was wondering about the quality as well and you did point it out. I'm new to Pro Tools and are recording my first demo piece. There are so many things I need to learn but so far so good. Next item is the drum beat.
Old 06-21-2010, 10:29 PM
Midi can be transposed freely with no issues(if you print the audio from a midi instrument, you can transpose the midi track and reprint any time). As for audio tracks, Elastic Pitch can do it within a few steps, but I much prefer Serato Pitch 'n Time and have shifted plenty of songs by 3-4 half-steps with excellent results. If you try Elastic Pitch, copy the session(File>Save Session Copy...and check the box for "copy all audio files". The reason for this is; sometimes(too often for my taste) Elastic Audio( and Pitch) can leave gross artifacts. Having the original session available, makes a nice backup if you need to retrieve audio files to replace corrupted files(EA and EP can leave gurgling sounds sometimes). Use Elastic Pitch for transposing audio, you MUST use Polyphonic and then right-click the region to bring up Elastic Properties.
Old 06-22-2010, 08:05 AM
I will give it a try and see how that goes. Thanks for the tips!
Windows 7 64 bits, Pentium Dual Core 2.6GHz 4GB RAM, Pro Tools LE 8.0, Mbox 2
Old 06-22-2010, 07:42 PM
Albee1852,
I finally figured out how to enable the track to elastic audio and followed your instruction to do the change and it works fine. Thank you!
Old 06-22-2010, 08:55 PM
:d:d:d
Old 05-19-2011, 04:59 PM
CherylD CherylD is offline
I have enabled the elastic pitch for my audio tracks. Then I am able to select the regions for each track and right click to bring up elastic properties, but I'm lost what to do from here. I see the semitones box, which goes up or down in + or - numbers, but I'm going down 1 1/2 steps (from Bb to G). I'm just not sure how to get there. I'm working in PT8.0.4.
Also what about my midi tracks? Will they adjust once my audio tracks have adjusted?
Thanks for any help.
Old 05-19-2011, 10:01 PM
-3 semitones is what you need to go from Bb to G. Midi tracks need to be done separately. Highlight the midi info and call up the midi transpose function(I think that's under the Events menu).
Old 05-20-2011, 11:06 AM
Thank you so much. That worked beautifully for my audio tracks. However, I wasn't so lucky with my midi track. Let me ask you this. I deleted the information from my midi track once I transferred it to the instrumental track. I tried to do what you said about the midi transpose window, by lowering it -3 semitones, but that didn't work. Since I deleted the midi data, am I out of luck with the instrument track?
Changing tempo in a song help! WilliamBolt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2010 02:57 PM
Changing Tempo Mid-Song Jason Kardong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-20-2007 01:54 PM
Changing BPM on a song MikeSoloway 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-16-2006 01:25 PM
changing the key of a song... dkinman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-31-2005 08:58 PM
patches changing in mid song???? jrock237 MIDI 3 09-03-2001 06:20 PM
