Old 09-23-2009, 03:23 AM
gyemusic gyemusic is offline
Default best ADAT 8 channel pre
Im ready to step it up from this digimax. I have it pretty much narrowed down either getting a audient asp008 or an apogee ensemble.
anybody have any opinions on the two? Or perhaps a better solution? I have about a 3k budget for better clock and a/d.
Old 09-23-2009, 05:42 AM
1ace1 1ace1 is offline
Default Re: best ADAT 8 channel pre
Apogee does sound great on its AD conversion.
Am just about to try out the focusrite ADAT bridge today as we have had three arrive, just putting expansion boards in now :)
A:)
I Love Audio!!!
Old 09-23-2009, 12:20 PM
kidbazooka kidbazooka is offline
I like the Audient. Maybe a tad too clean, but it's been real dependable and was a huge step up when I mothballed my Digimax. It runs a bit hot so leave a rack space open above it.
Hrdw: Mac Pro 3.3gHz 6-core (2012) 32gb RAM, Digi002 w Blk Lion mod, 2 UAD2 Quads, Dynaudio BM5A, KRK 10S, Sftw: 10.8.5, 10.3.7, Pres: Chandler TG2, A-Designs Pacifica, Focusrite Red 8, UA 2-610, Aurora GTQ2, Audient 008, Mics: Peluso 2247SE, P67 and P12, Gefell M295, R121, RE20, 4038, R84, 414, 421, KM184, SM57, SM81, AKG D19, D12, D112, Audix D6
Old 09-23-2009, 12:57 PM
sonny7 sonny7 is offline
Hate to sound like a newbie, but is the adat out a better way to go than the light pipe??? (or are they the same?)
I am trying to add 8 more pre's but if I can get better pre's than the digi 003 that would be great \as well
thanks
mac pro, 2.66ghz 4gigs ram, 1 internal 250 and 1 internal 500 hard drive, digi 003 board, PT 7.3
www.James Angelucci.com
Old 09-23-2009, 05:19 PM
The Dougfather The Dougfather is offline
ADAT and lightpipe are the same.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 09-23-2009, 05:52 PM
CamM CamM is offline
can be the same.
Old 09-24-2009, 05:20 AM
Razorfish Razorfish is offline
Audient is a great unit for the price. Sounds nearly as good as other pres costing a lot more, and the conversion is pretty good too, from my experience of it.
Old 09-24-2009, 11:00 AM
My opinion (YMMV) is that most 8 channel ADAT based mic pres are similarly neutral. The target consumer is one that needs more standard mic inputs for everyday general purposes. If you want really good mic pres, you are probably going to need to go with 1 or 2 channel units through a high end A/D converter such as the Apogee Rosetta 800 or similar unit. You can also go in throught the 003's line ins (channel 5-8). There is no one size fits all solution. You need to match the source to the mic to the mic pre to the A/D converter, etc. Sometimes we get to hung up on the mic pre and hope that it will magically fix what is wrong with the rest of the chain or the room. While the mic pres on the DigiMax and the 003 are fine for drums or other instruments, I'll usually go through my Universal Audio LA610 for vocals and try different mics until I get one that brings out the best from the singer. I know this sounds like a "non answer" but it is my honest opinion.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 10.15.2 running Protools 2019.12.0
Old 09-25-2009, 09:21 PM
does anyone use the ensemble for adat?
Old 09-26-2009, 01:28 AM
MetalMike MetalMike is offline
Apogee Rosetta hands down
No channel pan when using adat... malfunction 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-13-2009 06:16 AM
How do I transfer a 16 channel adat into my 002 Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2005 07:26 PM
New 8 Channel Mic Pre ADAT proaudio3645 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-26-2004 02:32 PM
8 Channel Analog-to-ADAT Converter Straatocastoer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-25-2004 08:32 PM
Recommendations for 8-channel mic pre w/ADAT out? dbrunell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 12-31-2003 08:07 AM
