Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-14-2009, 12:23 PM
kevinc333 kevinc333 is offline
Default Signal strength over distance
How far can a typical microphone/line signal be carried over a standard cable or snake? At what point do you need to boost the signal?
Old 01-14-2009, 05:41 PM
tha]-[acksaw tha]-[acksaw is offline
Default Re: Signal strength over distance
i don't have the answer (sorry about that), but this is a great question. i would love to hear some info about it.
and if anyone has any info, here is another question...
whats the best way to boost the signal when getting into this dangerout terratory.
thanks!
www.TheSoundCoop.com
www.youtube.com/TheSoundCoop
PCAudioLabs 2.5GHz Quad-Core Q8300 FSB:1333/1066MHz, NB:IntelG33, SB:Intel ICH9DH/WinXP Pro SP3 / SATA HD's = 160GB(7200/8), 320GB (7200/16) x 2,500GB (7200/32) / 4GB DDR2-800 / FW = TI ChipSet / Gear: Apogee Rosetta800, ADL600, Avalon2022 // M-Audio = Profire Lightbridge, Octane 8's, BX5's BX8's & SBX // ProTools MP 8.0.5 w/ MPTK 2 - Velvet Waves Sonnox IK NI FXpansion Massy -- DVerb2.0 Test = 230 verbs
Old 01-14-2009, 06:00 PM
DigiTechSupt's Avatar
Mic signals can go a long ways - 100+ feet or more, because they're low impedance signals.
Line level signals, on the other hand, start to peter out around 25 feet, as they're high impedance. Converting to low impedance (with a direct box) allows you to run them for longer lengths. That's the best method, as continually boosting the signal just raises the noise floor of the signal, degrading sound quality.
Avid Audio Tech Support
Support FAQ
Old 01-14-2009, 07:21 PM
Barnabas Barnabas is offline
Unless by "line signal" you mean a balanced line signal, like what goes between a mixer and an amplifier or between a preamp and a balanced line input on a recorder. Those signals can travel much farther then a mic signal without degradation of signal.
In a large-venue concert, you might have mic signals traveling down 300 feet of mic cable/snake cable to get to the mixer. The signal looses a little something going that distance, but it's OK for live sound, but might be noticed in a recording. Converting to digital on stage (close to the mic) can cut down on a lot of the long-distance loss.
I have run a dynamic mic through over 1,000 feet of cable for an outdoor event with no problems, but then that was for a sports announcer, not for critical music.
If your recorder is a long distance from the microphone, it's best to keep the mic cable short and allow the cable between the preamp and the recorder (assuming a balanced line) to be longer.
Some recording trucks will place their preamps on stage and then run balanced line-level signals out to the truck.
www.barnabas.com Barnabas MultiMedia
Old 01-15-2009, 10:22 AM
I should have clarified that. Line level, unbalanced, high impedance signals is what I was referring to. Balanced, lower impedance (but not as low as a low-impedance microphone) signals can also be run long lengths without any noticeable signal degradation.
My numbers are also extremely conservative, fwiw.
Support FAQ
Old 01-15-2009, 11:17 AM
Talking Re: Signal strength over distance
Thanks for the help!!
Strage Beat Detective Conform Strength Behavior sleiweke Pro Tools 10 0 02-06-2012 02:02 PM
OT - how do you distance yourself? Stig Eliassen General Discussion 19 10-27-2010 04:43 AM
Maintaining volume strength in fades? Ken P Tips & Tricks 3 10-13-2006 12:53 PM
Managing input signal strength during tracking liv dicknash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-11-2004 09:53 AM
Using one signal to lower the volume of a second signal for distance learning? Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-23-2003 01:54 AM
