Old 11-28-2008, 06:03 AM
djmichael.london djmichael.london is offline
Default How good are seagate drives?
Need to buy an external drive and there are some good deals for seagate drives this weekend for 500gb & 1tb. Does any1 use this brand? I've always used WD but dont wanna pass these deals up if they are worth it.
MichaeLondon
Mac : IMac 3.0 ghz/OSX 10.6.8/Mbox Mini/PT 7.4.2
DAW : Pro Tools 7.4.2 - Mbox Mini
www.myspace.com/michaelondon
Old 11-28-2008, 06:39 AM
dogon dogon is offline
Default Re: How good are seagate drives?
Hey Michael,
I have been using WD and Seagate for a good Ten years and all good.
Hope this helps
dogon
Old 11-28-2008, 06:57 AM
The Dougfather The Dougfather is offline
In my experience i have found WD to be the most unreliable makers of drives, Seagate are one of the best IMHO, it's what Glyph load their enclosures with. You might want to check the chipset, last time i checked seagate did not use Oxford.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 11-28-2008, 08:14 AM
As The Dougfather said, I would be concerned about the chipset but not worried about the drives. My failures over 5 years have been to WD and Maxtor(check the length of the warranty).
Old 11-28-2008, 08:58 AM
docbop docbop is offline
Seagate has always been one of the upper tier drive companies for many years and as DougFather points out that is what Glyph uses in their systems. I have used WD drives at home for many years they are good drives for the money, but do get noisy over time. To be clear I'm talking about raw drives. For externals I usually buy cases and fill them myself. Whether you buy external or make your own you have to watch the chipset used in the case very important for PT use.
Steve B.
If you think you can or if you think you can't, you're right.
Old 11-28-2008, 09:15 AM
Dogfather can u elaberate what you are talking about. (glyph etc..) sorry.
MichaeLondon
Old 11-28-2008, 02:16 PM
dougied dougied is offline
Along with the Glyph drives and you can also check out http://www.macsales.com and take a look at their FireWire hard drives too. They are pretty inexpensive and stable as hell.
Mac Pro Dual Quad 2.8Ghz 2008
MacBook Pro i7 2012
OSX 10.8.5 - OSX 10.7.5
Pro Tools 10.3.7 - 11.1.2
6GB RAM
Universal Audio Apollo Quad!!!
Eleven Rack
Focusrite Octopre MKII
Yamaha HS80s
Rockit RP5 Monitors w/ RP10 sub
Old 11-28-2008, 11:05 PM
Hugen Hugen is offline
I've used Seagate external and internal drives for years and have never had a problem with them. They seem rock solid.
I've had trouble with OWC customer service in the past, so stay away from them now.
I've had good luck with Glyph external HDs so far.
Old 11-29-2008, 09:29 AM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
as long as seagate isn't in a Lacie enclosure ur fine... they're good drives...WD on the other hand, NO'SKI...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-29-2008, 11:46 AM
hki hki is offline
I've only used seagate drives when I build my own. When I buy a pre-built drive,it's only from OWC.. macsales
"It is better to remain silent and thought a fool than to speak and remove all doubt".
Seagate FW drives and PT Media Man Pro Tools TDM Systems (Mac) 11 12-29-2006 11:58 AM
Seagate Hard Drives Good Deal 14choirs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-17-2006 11:23 PM
Seagate Drives steve0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-13-2001 11:03 PM
Seagate Drives Dean Bohana 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-26-2000 07:29 AM
seagate "LW" drives tripit Pro Tools TDM Systems (Mac) 1 12-28-1999 07:24 AM
