Old 12-29-2008, 06:47 PM
bkwalker510 bkwalker510 is offline
Default Connecting Sub to 003 rack
Greetings!
I am new to the 003 world and have just set everything up. I am using Yamaha HS 50M monitors with the HS 10W sub. I can't seem to figure out exactly how to hook up the monitors and the sub so that both are functional at the same time. I have the monitors hooked up to the main monitoring inputs on the back of the 003. Where does the sub go? I had it in the Alt ins, but then it would only activate when the Alt button was selected on front, thus nullifying the monitors... This may seem dumb but I am stuck. Any help would be great! Thanks a lot.
Old 12-30-2008, 08:56 PM
Barnabas Barnabas is offline
Default Re: Connecting Sub to 003 rack
I don't have any of those speakers, but a quick look at the sales literature seems to indicate that you connect the subwoofer to the 003 monitor outputs, then connect the full-range speakers to the outputs on the sub.
www.barnabas.com Barnabas MultiMedia
Old 01-02-2009, 01:12 PM
DrFord's Avatar
DrFord DrFord is offline
You may want to get your hands on a passive studio quality crossover, I would hesitate to be filtering my monitors signal path through the electronics of a subwoofer. You need precision in monitoring and any degredation will only hinder your ability to mix well.
I have the Central station, and after a member of the DUC advised, I plugged the output of my Mac's optical into the Central Station as well, now it has everything from both the computer and my PT rig.
http://www.sweetwater.com/c417--PreS...tor_Management
Good luck...
DRFord
Homepage | Facebook | YouTube
Mac OSX 10.12.6 | Mac Pro 5,1 | 12core 3.46ghz
Avid HD Native PCIe Core | Pro Tools HD 2018.1
Connecting Eleven Rack to Digi 002 Rack TMitchJobe Eleven Rack 12 02-02-2013 11:54 AM
Help Connecting 003 Rack and C|24 GCSC ICON & C|24 5 07-12-2011 12:00 PM
003 rack not connecting decayd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-07-2008 09:42 AM
002 Rack Not Connecting to G5 majikdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-20-2008 02:52 PM
rack not connecting andymae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-18-2007 06:14 PM
