HFS or HFS+ disk format
recently read the General Setup post by Digi on OSX PTLE6 uses HFS+ only!?
Coming from OS9 and using HFS for audio files, and getting PTLE6 running on my machine, I have already recorded on a disk which has HFS not HFS+ Is this just propaganda? or brainwashing? or .... If there is a distinct advantage of HFS+ over HFS can someone please educate me? Thanks! ebc
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
Re: HFS or HFS+ disk format
No brainwashing.... This is straight from Apple's Knowledge Base. You definitely want to go with HFS+ (Mac OS Extended).
What is Mac OS Extended format? Mac OS Extended format is a hard disk format that increases the number of allocation blocks on the disk. This format also allows more than 65,000 files on the hard disk. Mac OS Extended format optimizes the storage capacity of large hard disks by decreasing the minimum size of a single file. What are the differences between Mac OS Extended format and Mac OS Standard format? The most visible difference between Mac OS Extended format and Mac OS Standard format, other than the minimum file size, is the maximum number of files.
PM G4 Quicksilver 867 1.25GB RAM OS 10.3.8 Panther Pro Tools 6.4 Digi 001 |
HFS+ = better written files = more available space = more stability even when drive gets full. One of the biggest advantage is (this is just an example, numbers not exact) a 30 Gig drive formatted HFS results in 24 Gig of usable space.(ie:12 x 2Gig files will use 28.6Gig of space) a 30 Gig drive formatted HFS+ results in 28.6 Gig of usable space.(ie:12 x 2Gig files will use 24Gig of space and leave an extra 4.6Gig of free space.)
"Sorry! I didn't hear you. WHAT DID YOU SAY!" PTLE 5.1.1 Digi001 MacOS9.2.2 Yikes!400MHz |
How to bounce mp3 format to disk? | tommykoot | Pro Tools M-Powered (Win) | 6 | 11-05-2010 05:13 AM |
Disk format for protools help | joji | Pro Tools TDM Systems (Mac) | 2 | 08-15-2010 12:40 PM |
bounce to disk what format should i use to listen | lenno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-26-2004 05:58 PM |
Can't Bounce to disk in Mp3 format.... | Gwanillium | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-16-2004 08:54 AM |
Session in WAV format; bounce to disk in SD II?? | el biciclista | Pro Tools TDM Systems (Mac) | 2 | 02-05-2003 12:56 AM |
