Cannot figure out how to get my pedal board to work with the Elevenrack
I have read all of the posts regarding using the FX Loop, but I am not having any success. I'm in the Mac OS using ProTools 12 (most current version). I have the Elevenrack coming into my Focusrite Saffire Pro40 Interface via SPDIF, and it works fine. ProTools receives the sound from the 11R to record.
What I want to do is to use my pedal board which has 8 different pedals, plus a Cry Baby and Volume pedal in the chain. I have the FX Loop Send going to my input of the pedal board (where I would usually plug in my guitar). The output of my pedal board is (where I would usually plug into the amp) is going to the FX Loop Return on the 11R. I have those both to the mono "Left" positions, and the pin is UP set to stompbox. My guitar is plugged into the Elevenrack's Guitar Input on the front. In the EDIT/RACK on the 11R, I scrolled down and selected "FX Loop". What I hear is only the Elevenrack's preset, but with none of my pedals' sound. It's like there is nothing there. What I am trying to do is to use only the amp and cabs in the Elevenrack. I want to use the Marshall 100W and the Matchless amps coupled with certain cabs to achieve a sound (but it's crucial that I can run my own pedals through those amp syms). I do not know what the problem is. Any suggestions appreciated. |
Re: Cannot figure out how to get my pedal board to work with the Elevenrack
Is the FX LOOP button ON (green)?
You need the FX loop turned on (see Benoni’s question), the FX Loop levels and return % (I forget what exactly they call that in the FX Loop effects control) set correctly, the FX Loop correctly positioned in the Eleven Rack rig. Some of this stuff is described in the User Guide. Also read about the level meters on the Eleven Rack front panel display in the rig view, they are very handy.
You can do a null cable test just with the FX send jumped to FX return and play with the return % and confirm that works as expected. Including when you disconnect the cable. Then take a single really obvious effects pedal and turn the effect up to a super obvious amount and connect that into the FX Loop. Does that work? Are you using wah and volume pedal inside the Eleven Rack or physical pedals? Pedals turned on and good batteries or power supplies working? If needed test all cables one at a time in the null test and add pedals in the chain one at a time. Also test pedals one at a time by putting them between the guitar and guitar input. Sent from my iPad using Tapatalk Last edited by Darryl Ramm; 10-14-2017 at 09:46 AM. |
Thank you for your responses. I finally got it to work. The issue was that I always viewed the "FX Loop" pedal in the Elevenrack as some sort of effects pedal. I didn't realize that it actually controlled the level of what's coming in. It certainly isn't perfect, but I will figure it out.
I had the FX Loop turned on in the panel, but the level of it was turned down. Once I raised it - boom, I heard my board. Awesome. I just saved like 50 billion dollars, and my neighbor's well being. |
It is behaving like a parallel effects loop on a real guitar amp. Well except it’s not really between the amp preamp and power section. and as always depending on the effects you might be better off placing them between the guitar and amp, not in an FX loop.
Sent from my iPhone using Tapatalk |
You may get a better sound by plugging you guitar in your pedalboard and the ouput of the pedalboard in 11R guitar in to use 11R TrueZ. This should sounds/reacts the same way as a real amp.
Vintage Boss BCB-6 with PSM-5 Power Guitar Pedal Board - Japan - BCB 6 - Bass | nexis | Buy & Sell | 1 | 02-12-2013 09:21 PM |
Will an external sustain pedal work with midi? | CPG | MIDI | 2 | 12-13-2011 07:47 AM |
Sustain pedal cuts out while recording. Can't figure it out. | jmeharry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-09-2009 09:13 PM |
anyone figure out how to get 6.1.1 to work | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-09-2003 12:21 PM |
Help me figure out to install and work my digitech | Summer Snow | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-08-2003 05:05 PM |
