Re: Auto Tune 7 even worse!! than EVO
Also, aside from the crashing - Do you feel there is a big change in its sound? How about the time-comp/exp feature? Interested in some 1st impressions of it (minus the crash thing - since I use 6-8 at best). Lastly, only since you didnt mention it, did you trash DAE prefs etc and AT5 prefs (if there even are any, I forget) after installing, and remove AT5/EVO from plugins folder? I know its the basic stuff, but you never know. Just curious. Thx MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8 PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626 •••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!• |
TH |
But, Yes I would buy a good plug if I can only get 10 instances of it. My CL1B uses one chip per instance, I think, and I could never manage 10 if I had a lot of other DSP hogs working. BUT...It sounds virtually as good as my hardware CL1B.. you can do the math. But 40 instances of a tuning plug? are you using it for effect, or are they all that out of tune? ff |
You do understand that your available TDM chips have nothing to do with instantiating rtas plugs? In your first video, you made a point of showing that you had at least 4 open tdm chips, yet you instantiated rtas plugins. If you are testing the resources of rtas, having available TDM chips has nothing to do with your machine's available resources. But I think you know this, right? Do you suppose that there is a resource limit for AT rtas plugs? As others have mentioned -- you may simply be loading too many for your CPU or machine's resources.
--Jeremy |
It's not that simple, and this shows that you are not doing modern pop productions....it isn't a question of "doing it again".... TH |
#16
Edadema, how much ram in your macpro? Considering you are encountering out of memory errors, it would be useful to know how much ram is avail.
If you can make another video, this time launch the mac utility, Applicatons/Utilities/Activity Monitor.app and watch the ram usage display -- and report what happens when you add 8, 9, 10, 11 instances, etc... Virtual instruments (using Ve Pro) has taught some of us to NOT watch the protools resource window -- rather, look at the computer activity monitor for an unbiased look at ram and processor usage. This may help you figure out what exactly is failing, and when. J
--Jeremy |
#17
There where no VIs in the session and the one where I made it crash it was empty mono tracks |
#18
"It's supposed to work"? Well yeah, but there are physical limitations based on your hardware. Ask the developer the number of instances intended spec... you know what the answer is going to be. As Rail said earlier, there are settings in AT that you may want to look at -- or maybe print 8 tracks of AT at a time and disable the plug. There are too many superb singers in NYC, so having to tune BGV x 20+ tracks is not something I have ever needed or wanted to do. Tuning here is usually of the spot variety (or simply just tune the damn thing), even with my "tv star" clients. And yes, we are known to stack dozens and dozens of BGV -- but if I had to slap a tuner on 20+ tracks, I'd fire the BGV singer first (or shoot them, whichever would cause the least trouble). I think your expectations for using 20+ instances of AT may need to be checked with the developer.
--Jeremy |
#19
I love how everyone is in control of the content of their sessions and your going to "shoot the singer if their bad" and "I only work with the best"..... Spare Me.. lol
I make my living making Bad and Average people sound Amazing. Also the Vocals are very important and the final part to the mix? So I need to be able to go deep with Auto Tune and have it make my life easier. Not more complicated So I don't want work arounds. Am I asking to much? |
#20
But please tell me what is the last thing you touch or make sure is right before you bounce a session. Please enlighten me????? |
Waves Tune and Auto-Tune Unhappy With HDX? | Logichead | Pro Tools HDX & HD Native Systems (Mac) | 2 | 11-25-2012 11:42 AM |
"Auto Rename" regions BUG ? IT GETS WORSE!!! | 25ghosts | Pro Tools TDM Systems (Mac) | 15 | 03-30-2011 07:25 AM |
vocal tune with Auto Tune 5 | martin coria | Pro Tools M-Powered (Win) | 17 | 08-06-2010 09:14 AM |
Upgrading Auto Tune 4 to Auto Tune Evo | summit01 | Pro Tools TDM Systems (Mac) | 0 | 10-16-2008 11:05 AM |
Auto-Tune 3 PT 7?? | zeeman | Pro Tools TDM Systems (Mac) | 3 | 01-13-2006 10:53 AM |
