Old 05-24-2019, 02:10 PM
the19thbear the19thbear is offline
Default Re: Pro Tools vs Reaper
Tried to switch years ago but couldn’t. I am pretty fast when it comes to editing in pro tools, and i tried to configure reaper to act the same way as pro tools, but it couldn’t be done. Hotkeys can be set up but mouse behavior can never be the same as pro tools. It was not worth it for me to switch.
Old 05-24-2019, 02:17 PM
Norbertools Norbertools is offline
This is weird, because it is super easy and all possible in Reaper.
Old 05-25-2019, 05:28 AM
dougdi dougdi is offline
What I miss in Reaper is trim automation and the ability to have more than one video file in the timeline. Oh, and AAF import and Audiosuite. And a few others I can’t recall at the moment.
Reaper is a not a good replacement for PT HD. It’s very close so I keep an eye on it.
Old 05-25-2019, 06:07 AM
eehm, all of this is no problem, trim automation e.g.
https://www.youtube.com/watch?v=1Svi7xQilRY
Where did you get all this misinformation from? Reaper can everything PT HD can do and much more.
Maybe this is interesting for you:
https://www.youtube.com/watch?v=BKCvJsG-zrQ
Old 05-25-2019, 11:39 AM
Seems like reaper has Update it’s mouse modifier capabilities. Will test.
Old 05-26-2019, 04:16 AM
I know you can manually trim but can you trim using external faders as the session is playing? I’ll check out these vids, I’ve been meaning to watch Nick's.
Old 05-26-2019, 04:27 AM
Docs state that trim can’t be written to using automation, that, for me, is necessary for mixing.
Manual says:
It is not a track parameter control envelope: it does not correspond to any track control and hence cannot be armed or written in write, touch or latch mode.
Old 05-26-2019, 05:17 AM
Ok, I understand Kenny's method but there are more steps involved that how PT does it. Still, multiple videos is a requirement as I can easily have over 100 clips to work to. Otherwise I think Reaper is awesome.
Old 05-26-2019, 05:53 AM
I think in Reaper it is handled via the project tabs. I think PT is awesome, too. Avid will have to react at some point and will invest to implement some other features from other DAWs.
Old 05-26-2019, 06:49 AM
I’ll take a look again. Do you need to use an external editor to emulate the function of Audiosuite?
Oh, another missing feature is AAF import/export. I know there’s an app that can do the translation.
Using Reaper to Host VST VI's in Pro Tools DonaldM Tips & Tricks 15 11-16-2013 10:49 AM
HELP! Reaper > Pro Tools Issues AlexDC macOS 6 06-20-2013 08:44 AM
Pro Tools 8 theme for Reaper? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-09-2010 07:51 AM
Pro Tools to Reaper... Need some help! DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 42 03-15-2010 08:24 AM
Reaper and Pro Tools 8? jebwick General Discussion 50 09-23-2009 07:20 PM
