Old 05-11-2019, 02:06 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default How to bypass plugin
hi friends !
Couldn't find a way if there is any to bypass a plugin within the artist mix . Some plugin have an integrated bypass or power button but I can't for a way to access them . Is this possible ?
Thanks !
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 05-11-2019, 02:28 PM
MoPro's Avatar
MoPro MoPro is offline
Default Re: How to bypass plugin
Originally Posted by jeam25 View Post
hi friends !
Thanks !
Hello, the functionality of the control surface greatly depends on each DAW developers implementation of their "EuCon Adapter"...
We need more info about your DAW, and which plugin for starters! Also is this plugin being implemented via insert, or send...etc.
Al
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 05-11-2019, 02:34 PM
jeam25's Avatar
hi well DAW is PT and let say Teletronix La2a from UA .
Thanks !
Protools Ultimate
Old 05-11-2019, 02:35 PM
BScout BScout is offline
hi friends !
Thanks !
Just double checking, you don't want just to bypass the plugin from Pro Tools' controls (which is just the "on" button near the top knob) but something within the plugin?
Can you give an example plugin (hopefully not UAD)? Does that show up as an automatable parameter?
Old 05-11-2019, 02:41 PM
Ok. Found one that the in-channel "power button" wasn't linked to the plugin's normal bypass (a lot are so the "on" button works to bypass). DMG TrackControl. However, it is an automatable parameter and bypass works from there on the Artist Mix.
Old 05-11-2019, 02:48 PM
jeam25's Avatar
Hi Bscout I'm a little lost there !
well for me can be the " internal " power button or the normal insert bypass doesn't matter as long I can bypass it to compare processing vs nothing .
Protools Ultimate
Old 05-11-2019, 03:01 PM
Normal bypass is the easy one.
With the plugin name visible on the top display ("Inserts" mode if the plugin you want to bypass is just the one or hit flip so you can see multiple plugins on the channel), just click off the small "on" button under "SEL" sitting under the one that shows the plugin you want to bypass.
Old 05-11-2019, 03:18 PM
jeam25's Avatar
Great will try that later
Thanks !
Protools Ultimate
Plugin Disable & Bypass Soundtrack2life Pro Tools TDM Systems (Mac) 22 06-22-2010 04:10 PM
bypass plugin? jackp Pro Tools TDM Systems (Win) 5 05-12-2009 10:52 AM
Plugin bypass problem Werner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-02-2008 10:17 AM
Automate plugin bypass? mixerboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-07-2005 10:50 AM
bypass a plugin without charging CPU ? saltine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-10-2003 08:57 AM
