So PT12 is actually slower than PT11?
At least according to Pro Tools Expert: https://www.youtube.com/watch?t=16&v=uF-l2zPa3Uo
https://www.youtube.com/watch?v=V9X-aUDc0Uo |
Re: So PT12 is actually slower than PT11?
So many people seem to be reporting conflicting results : Pro Tools 12 is so much better than Pro Tools 11. Pro Tools 12 is so much worse than Pro Tools 11. Pro Tools 12 is identical to Pro Tools 11. I think it may well come down to the individuals installation of the software : Some people uninstall the old version, and do a clean install of the new version. Some people install the new version straight over the old version. Some people seem to have a good luck day, where a software installation just seems to work perfectly. Some people seem to have a bad luck day, where a software installation just doesn't quite seem to work perfectly. My guess is they're essentially the same. I'll give Pro Tools | First a go, when it is released, as it is possible to dual install along side PT11. If it works well, and if Avid deliver on their promises by the end of 2015, I may well upgrade for year 1. They'll have to stay true throughout the following years, for me to continue remaining up to date. |
I trust Pro Tools Expert more than Avid. I trust what I see. I don't care abt "Some ppl", I do care about what Avid can provide us beside SH*T! |
It is faster for me. Startup on 11 was way slow 12 is much quicker. I think the problem is Avid claims you can have two versions if they are all after 10 but performance suffers if you don't remove all traces of the old version.
It still depends on whether you set it up correctly. |
I believe actual tests like what was shown in the video. If it's faster for others, I would love to see some proof. It's easy to state it's faster, let's see it.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. |
Not slow here! It's "Initializing Midi Engine" by the time I look up from the task bar. I can change plugins on the fly with nary a glitch in audio or visual performance while a session is playing. I like it!
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
What kind computer Sugarnutz?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
The bottom one listed in my sig:
Gigabyte GA-Z97X-UD7-TH Motherboard Intel Core i7-4790K Haswell Quad-Core 4.0GHz CPU 32 GB of Crucial Ballistix Sport 240-Pin DDR3 1600 EVGA SuperClocked GeForce GTX 760 Video Card Cooler Master HAF XB EVO Case Crucial SSDs & Velociraptor 10Ks Win 7 Ultimate 64 bit Just loaded up a 12+ track session of "Butterflies" from Sweetwater stems along with the corresponding 720p MP4 video from Youtube imported into the session, plus plugins for the audio and the video played perfectly even expanded out to cover 75% of the monitor. Working great here.
There is some possible issues here as SSD's for instance will cache the most frequently used data for even faster response times. Were they both launched once before the test to get the sessions in PT cache?? There is some easy ways to fudge this test. Also depending on your workflow, not having the "I/O's changed" window pop up evey time you launch a session counts as time also which is a biggie for me.
The title of this thread is aso false. It should read "launch time slower" as that's all this is checking
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Why PT12 might be very similar to PT11 | trevora | Pro Tools 12 | 1 | 03-29-2015 06:01 PM |
PT12 requires surrender of PT11? | SBP | Pro Tools 12 | 3 | 03-25-2015 06:25 PM |
PT12 upgrade cost from PT11 | makinghits | Pro Tools 12 | 0 | 03-24-2015 08:18 AM |
PT12 sessions in PT11 questions | musicman691 | Pro Tools 12 | 12 | 03-24-2015 08:10 AM |
Upgrade from PT11 to PT12 Cost | SearingSounds | Pro Tools 12 | 208 | 03-23-2015 08:12 AM |
