Re: PT9 Command 8 with another control surface
What about the 003, can you use another unit with it?
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors. MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp |
If you're referring to a Euphonix Artist series then, yes, you can.
In testing this, however, we came across one issue with using EuCon and 003 - the 003 will no longer bank forward. You can nudge forward and backward and bank backwards, so it may not be a big deal. We'll obviously get this logged and looked at. |
Digi, I use a 002 and a mc mix, I want to add another mc mix, but would like to change the order of the devices, is this possible?
I would ideally like to see 1-8 mc mix, 9-16 002, and 17-24 mc mix#2. It will look nice on my desk space. I tried rearranging just the two in my control setup menu, but to no luck. Am doing something wrong? |
I'm trying to use a Command 8 alongside a Presonus Faderport at the same time. Faderport is working great by itself and so is c8 but together I can't get it to work. Downloaded the latest firmware. I go to prefs/midi controllers, set up my C8 then in #2 for the Faderport I go HUI/receive from-usb audio device/send to-usb audio device/#chs-8. I get the message "you have selected a midi controller that is not compatible with Command 8. Please deselect this device or remove Command 8 from your selection". Am I doing anything wrong? I really thought this would work. Is this a possibility or not?
PTLE 8.05 XP SP3 P4 3.06 2GB RAM 002R C8 Intel i865G VIA OHCI 1394 Firewire Radeon 7000 |
#16
#17
That is correct!
#18
#19
How about Controlling PT9 with Mackie Onyx 1640i ?
Thanks! |
#20
that is not a motorized unit. nor a full midi control unit.
Focusrite Saffire Pro 40 and Command|8 Control Surface | EmperorMusic | Third Party Interfaces | 2 | 02-15-2014 11:22 AM |
Can you bring an audiosuite plugin under d-command surface control | paulroberts | ICON & C|24 | 0 | 03-22-2010 01:24 PM |
Control Surface Question: Command 8 and Frontier Tranzports | solidwalnut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-09-2008 02:41 PM |
Control Surface - Command 8 vs. Mackie Universal?? | doylemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 02-24-2006 03:21 AM |
New command 8 control surface | blue demon | General Discussion | 13 | 04-07-2004 09:03 PM |
