cannot be designated as an Audio Record volume because it is not a valid audio volume
I have Pro-Tools LE 7.4.2 installed on my Macbook Pro. When starting a new session i cannot save it to any hard drive.I have an external hard drive i want to use for Pro-tools sessions that is partitioned for half mac (mac OS extended (journaled)) and half windows. I have tryed to change the letter under the 'A' in 'workspace' to 'R' for this hard-drive but this is when the problem occurs. My set-up is as follows: Macbook Pro- OSX 10.8.2 Processor- 2.5 GHz Intel Core i5 Memory- 8GB 1600 MHz DDR3 (This machine is bootcamped with windows 7 but Pro-tools is installed on the mac partition) Hard Drive - 1TB WD Ext HDD 1021 (Partitioned) Any help would be much apprieciated Cheers, Gav |
Re: cannot be designated as an Audio Record volume because it is not a valid audio vo
I didn't think that any LE version would run on 10.8 I'm also not confident on partitioning an external drive in 2 different formats. Why not make that drive all HFS+ and use MacDrive in the Windows install?(admittedly, I'm not a genius about Macs).
Firstly thanks for replying to my question, much appreciated. Since this morning i have reformatted my external drive to just be Mac OS Extended (Journaled) is this what you mean when you say HFS+? Excuse my ignorance. I have also tryed basically all the other formatting options for the Hard drive and none work. Every time i try to change the 'A' in workspace i get the 'not a valid audio volume' message regardless of format. I also tried reinstalling pro-tools. This copy of 'PT' was working on a PC previously with this hard drive (formatted for PC) only since i'v gone to the mac has the problem occured. Thanks again, Gav |
Pro tools 7.4 will not work with Mac OS 10.8. It ended with Leopard OS 10.5.
Here from AVID Pro Tools Software Versions Below 8.0.3 Are Not Compatible With Snow Leopard 10.6 You need at least 8.0.5 to work with anything above 10.7. and pro tools 9 or above to work with 10.8 mountain lion. I have 8.0.5 and havent upgraded to 10.8 yet as my 8 LE will not work. Chris
http://www.youtube.com/user/RegenerationMix http://soundcloud.com/regenerationmix http://twitter.com/regenerationmix MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7 |
Hi Chris,
Thanks for the unfortunate news, oh well cheers anyway! Gav |
Good evening folks.
I realize this is an old question, but I figured I could take this moment to possibly offer a solution for running Pro Tools 7.4 on Mac OS 10.7.5. I have this configuration because my Audio Interface is an M-Audio Project Mix I/O (Firewire) which is run by an older Mac Mini (Core 2 Duo). I run both Logic and Pro Tools on the system. Upon installing Pro Tolls 7.4 on the mac (with the M-Audio Drivers already loaded) and authorizing with my iLok, I was able to open the demo session with no issues (Had to configure the console automation settings in Peripherals). After opening the "Workspace", subsequent starts of the application resulted in the "Cannot be designated as an Audio Record Volume" error when loading the exact same session. Uninstalling and re-installing Pro-Tools restored the software to perfect working order. My recommendation (although a bit hacky) would simply be to stay out of the Workspace view. If I learn any better way to keep PT running, I'll be sure to update here. Hope this helps someone! -M |
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume | soloavenger | macOS | 7 | 02-15-2016 03:49 PM |
hd cannot be designated as an audio record volume because it is not a valid audio | wapeddell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-12-2010 12:05 PM |
drive cannot be designated as an audio record volume because | Capture | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-03-2007 10:06 AM |
drive cannot be designated as an audio record volume because | Capture | Post - Surround - Video | 1 | 05-03-2007 08:46 AM |
Cannot be designated as an Audio Record volume | mcgillicutty | Pro Tools TDM Systems (Mac) | 2 | 04-06-2007 02:27 PM |
