audio record volume?
Ive been having a weird problem lately. I try to save my projects on my lacie d2 firewire drive and it used to work fine, then one day out of the blue it wouldnt let me save it said it had to be saved to an audio record volume. I couldnt figure it out then after awhile i decided to upgrade to 6.4 from 6.2.3 to see if that fixed it and it seemed to work and now 6.4 is doing it as well so i have to save my projects to the desktop and i dont like it. Anyone know anything about this? thanks
digi 002 Powermac g4 Dual 1 ghz Powerbook g4 12 inch |
Re: audio record volume?
This can happen for different reasons. MAINLY for the # 1 reason I put,, but also check the other reasons if that doesn't work.. These are in order of what it most likely is:
1) Check hard drives in the workspace and make sure the ( A ) column is set to ( R ) and not ( T ) 2) Trash volume.dbb file on all hard drives. 3) Trash Pro Tools preferences. USERS/username/library/preferences/Pro Tools preferences OR Check to make sure you don't keep accidentally changing the date and time inside your computer.. Make sure the date and time is set to the CORRECT date and time, and on NORMAL time, NOT military time -- And never change it to be "incorrect" time on purpose.. |
cannot be designated as an Audio Record volume because it is not a valid audio volume | Gav_Russell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-15-2016 03:52 PM |
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume | soloavenger | macOS | 7 | 02-15-2016 03:49 PM |
Session must be on an audio record volume if permmited set the volumes to R record | lionandthemouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-11-2013 01:48 PM |
hd cannot be designated as an audio record volume because it is not a valid audio | wapeddell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 04-12-2010 12:05 PM |
cannot be as an audio record volume because it is formatted as a FAT volume | rtm | Pro Tools TDM Systems (Win) | 3 | 12-18-2008 09:52 AM |
