Bank Select on PT LE
When I pull up the patch selector on my midi track I can not find anywhere to change the bank. I am using a Siruis by Quasimidi and the only sounds I can get to trigger through pro tools are drum sounds I need to change the bank to trigger different sounds but the only parameters to change are Patch, controller 0 and Controller 32. I Know the PT Mix+ I use at work has a bank select option. Please Help
Mc mix-protools 9- bank select follow? | priorytools | Artist Series | 1 | 11-08-2011 10:57 AM |
Midi Bank select in 7.3 problem | a100man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-10-2007 08:22 AM |
PT drops out of record when using 'bank select'... | GVDB | ProControl, Control|24, Command|8 | 2 | 09-24-2006 02:19 PM |
Bank Select | Camilo Orozco | ProControl, Control|24, Command|8 | 1 | 09-01-2001 04:21 AM |
