Make Automation Lanes same on Edit Windows
I've defined automation lanes on the Edit window for a given track. These stay put when I change which window I look at. When I switch to the Midi Edit window, the automation lanes "default"? If I change to add the ones that I want (same as Edit Window), they can be added but do not stay if I change to another window. Is there a setting somewhere to have the Midi Edit window follow the automation lane definition on the Edit window? (P.S. - not the same automation lanes on every track). |
Re: Make Automation Lanes same on Edit Windows
Humm...
Maybe I'm confused here. I think if I select a range of the track I want to edit in the Edit Window - then the MIDI Edit window has only that track selected and does have that track's automation lanes the same as shown in the Edit Window. I was selecting a range on the timeline and its was selecting all tracks which caused the MIDI Edit window to have all tracks selected - then after deselecting the tracks I didn't want (all the others) - the automation lanes did not match the track I was trying to edit. Nevermind... |
Hide automation lanes? [solved] | dg27 | Pro Tools 11 | 6 | 03-14-2023 11:39 AM |
automation lanes closed after crash | lemieux | Pro Tools 11 | 17 | 07-06-2015 04:20 PM |
Naming Automation Lanes | DonaldM | Pro Tools 11 | 2 | 09-22-2014 10:32 AM |
How to Copy/Paste/Dup Automation lanes? - help! | superfiction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-15-2010 01:27 PM |
Controller, and Automation lanes. | JimC | Pro Tools TDM Systems (Mac) | 12 | 05-25-2010 08:28 PM |
