  #31
Old 03-04-2020, 11:51 PM
groovebrother groovebrother is offline
Default Re: How many Pro Tools 10 users in 2019?
Eh eh
From pro tools 10 on 10.6.8 I moved to PT10 on 10.8.5 because of UAD software
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
  #32
Old 03-05-2020, 10:29 AM
markus44uk markus44uk is offline
I am still running PT10 because I refuse to give up my Control 24 and don't trust the Neyrink software.
So I was thinking that if the VST to RTAS converters still work on current Waves 11 plugins (like Ovox for example), why couldn't we buy the VST versions of newer 64bit plugins and use the VST converter to run them in Pro Tools 10?
Am I missing something? Is it that none of the new plugins will work in a 32 bit ProTools full stop?
Next step is to see if I can upgrade to Windows 10 and still use my PT 10 system...
  #33
Old 03-05-2020, 03:32 PM
basslik's Avatar
basslik basslik is offline
Originally Posted by musicman691 View Post
Reinstatement goes all the way to the latest (2019.x) version of PT.
Thanks for the info. My concern is that I read that the Lynx AES PCIe only is working until PT12.4 ?, or is that just in Windows ?
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #34
Old 03-06-2020, 06:13 AM
JFreak's Avatar
JFreak JFreak is offline
Cannot answer that, but in case you need v12.4 you can just ask Avid Support. Avid Download Center has every version since v12.6 so that is already kind of "legacy".
Janne
  #35
Old 03-06-2020, 06:14 AM
JFreak's Avatar
Originally Posted by groovebrother View Post
Eh eh
Not a bad move. PT10 also works on 10.9.5 but isn't supported and uninstaller won't work. Just sayin...
Janne
  #36
Old 03-06-2020, 06:16 AM
JFreak's Avatar
Maybe someghing to do with PT10 and 32bit plugins? It is so long ago perhaps nobody is interested into coding a VST-RTAS wrapper that works with 64bit VST... just a guess, developer needs to get money out of the effort
Janne
  #37
Old 03-06-2020, 06:19 AM
JFreak's Avatar
Originally Posted by jgulyas View Post
I'm still using PT10, as I have no need to go any higher.
You might want to use some features of the newer versions though.
But I know where you stand. I also have a PT10 live rig (HD3/PCIe) and a PT8 monitor rig (HD3/PCIx) and with all hardware there just comes a time where upgrade is not possible or practical. Just park it there and use as long as it runs.
Janne
  #38
Old 05-23-2020, 12:52 PM
basslik's Avatar
I contacted Avid support Friday requesting PT 12.4. How long does it typically take to add on my accountant ?
Also why is it that only 12.6 and up is listed ?
I have 10/11&12 in my accountant. THANKS.
  #39
Old 05-23-2020, 01:06 PM
JFreak's Avatar
I have no idea how crowded their support team is in this COVID time right now. Maybe they have chosen 12.6 because that is the first version that requires DigiLink I/O license? Who knows.
Janne
  #40
Old 05-31-2020, 04:44 AM
Talisker Talisker is online now
I am still on PT10 today and it is rock solid and I see no real reason to upgrade into nowadays structure. Also I havve not problem with new waves plugins, so far I could install everything using an offline installer.
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Pro Tools 2019 ! abomeerza Pro Tools 2019 1374 05-14-2019 07:13 AM
S5 & Pro Tools 2019.5 MarcOFB System 5 6 05-13-2019 08:15 AM
