Re: Is there a way to undo plugin adjustments just like everything else.
the sad reality is sometimes I spend two hours in B, and A still sounds better.
kickin' at the darkness 'till it bleeds daYlighT
Before you change the plugin parameters, press Cmd/shift/C (don't know the PC shortcut). That copies the settings into clipboard. Do some changes. To get back to the original press Cmd/shift/V.
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Also, I highly recommend that you take breaks regularly. That will reset your ears in a way that no undo function can.
^ This.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Undo of plugin parameters is possible!
You just have to enable automation to all parameters of your plugs. I myseelf have the preference clicked that all parameters are automation enabled when the plug is inserted. I can easily undo/redo a plug parameter. The edit window says "undo/redo change control window" This helps a lot when a track has no recorded parameter automation on it. Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
#16
I just save plugin settings .I find that often they can be a good starting point or before I have the chance to EQ I will use them temporarily. I have never imported a plugin setting just audio or sessions.
#17
Do I have to use the write to end or start. If adjustments are made they recorded as automation are they not . So at that point in the song only then will it automate to the adjustments made. TRUE/ FALSE . Or is it just a automation setting like "write" so it effects the track entirety. This is a good idea could you be more specific about this process please. |
#18
no auto is written unless you choose it to.
the control changes show up in your undo queue. e
ihatetyping |
#19
The beauty of importing plugin settings and assignments, is that you can tweak away like a mad scientist on all the tracks, totally screw up the mix, and then simply import the "before" settings from one of the backup files. Much more convenient than saving presets for each plugin on each track IMO. It's also been great to have this option when I've made a mistake, like removing plugins from the wrong tracks. No worries - import plugin assignments and settings from the backups. It really is a powerful feature.
#20
Is there a keyboard short cut for saving plugin settings.
Fader Adjustments | digi003 | Pro Tools 10 | 6 | 12-09-2011 04:34 PM |
DTS: No 'Q' adjustments on EQ3 w/MC Control | postprosound | Artist Series | 1 | 12-17-2010 09:14 AM |
Tab to transient adjustments? | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-15-2009 09:39 PM |
keep the fader UNDO and edits UNDO separate | uno1234 | Pro Tools TDM Systems (Mac) | 5 | 12-06-2005 09:30 AM |
I can't undo record audio, I CANT UNDO !!! | Dither16bit | Digidesign Hardware & Software | 0 | 06-09-2004 01:53 AM |
