Old 04-08-2021, 06:06 AM
MrTOe MrTOe is offline
Default Error: Assertion in "d:\...cpp", line 1701.
Hi everybody,
I am using a Dell XPS 13 9365.
I installed a focusrite scarlett 2i2 3rd gen and Pro Tools First. I open Pro Tools First as administrator, because otherwise I also get an error message. When I try to create a new project (doesn't matter if I take one from the template or not), I see the following message:
Could not save as "0000" because Assertion in "d:\ code\ scm\ protools\ release\ 2020\ r2\ protools\ app\ document\ uprojectbundlemgr.cpp", line 1701.
Anybody out there who can help?
Thanks in advance!
Old 04-08-2021, 07:02 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Error: Assertion in "d:\...cpp", line 1701.
First, make sure you are using the latest version of Pro Tools First. You can get the latest from your Avid account in the My Products section.
Next make sure that Windows is not using your audio interface as the default sound device.
Lastly, check to make sure that your Focusrite is the active device in the Pro Tools Playback Engine. If you are having trouble getting to the Playback Engine, hold down the N key while Pro Tools First is loading and wait until the Playback Engine dialog is displayed.
After doing all of these, try to create a new session.
Will
System Details
Old 04-09-2021, 11:31 PM
Hi Will,
thanks a lot for your answer!
I installed Pro Tools April, 1st, the version is Pro_Tools_First_2020.9. So that should be the right one. I also followed the other steps, but unfortunately it didn't help. Any other suggestions?
Thanks in advance and have a nice weekend!
Old 04-11-2021, 09:54 AM
Netmania Netmania is offline
Newest Version is Pro Tools 2021.3. Please try that and make sure that Pro Tools First and it's directories are all installed on Drive C: .Otherwise it won't work.
Best
MacBook Air M1, 8 Gb, 512 GB Apple SSD, 512 Gb Samsung Evo 970 NvME TB3 SSD, 1000 GB Crucial P1 TB3 SSD, macOs 12.3., RME Babyface blue,
macOs Sonoma 14.4.1
MacBook Pro 13, Mid 2012, 16 GB, 250 GB Crucial MX
macOs Sonoma 14.4.1 / Windows 11
_____________________________________________
Pro Tools 2022.7
Logic Pro 10.8.1
Cubase 12.07 Elements
Wavelab 11.2 Elements
Music was my first love - shine on
Old 04-20-2021, 01:37 PM
Mahieu Mahieu is offline
Originally Posted by MrTOe View Post
Hi Will,
Each time I heard something about this crash, the hardware is a Dell.
I have the same problem with my Dell / Realtek.
I have switched to another DAW as there is absolutely no solution.
Could not create a new document because Assertion in "/Volumes/Dev..." line 1813 theholdingcoat macOS 24 01-15-2023 01:31 PM
Error Messages- "Read Only" & "Assertion" KimmieMcD33 macOS 4 05-23-2017 03:20 AM
Help for Error Message - Assertion in "..\Mdie_TrackPlayer.cpp", line 476 lbpease Pro Tools 10 7 01-05-2014 12:15 PM
Recording error Assertion in"/line 476 fast track pro. Rizen macOS 2 12-10-2013 03:58 PM
assertion in "..\Mdie_TrackPlayer.cpp", line 469 / access violation/ DAE error -9400 thibault 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-22-2013 05:08 PM
