Old 07-24-2013, 12:15 PM
GuyPicks GuyPicks is offline
Default Anyone using the Focusrite Saffire 56 with PT 11?
Is anyone using the Focusrite Saffire 56 firewire with Pro Tools 11?
Will it connect with the 192 blue or the HDx card?
Thanks
System 1---------------------System 2
MacPro 5,1---------------------------Windows 10
2-CPUs-------------------------------i7-CPU
OS X 10.14--------------------------Pro Tools 2019.5 HD
PreSonus 1824c --------------------HDX / 192 Analog
Fader Port---------------------------2-24" monitors
NI S61mkII--------------------------32GB Ram
64GB Ram---------------------------4 internal Drives
5-Glyph Rack Drives----------------Presonus 192 Mobile
2-24" Monitors----------------------Nektar Impact LX88+
Glyph Raid 4
Old 07-24-2013, 12:46 PM
nst7 nst7 is offline
Default Re: Anyone using the Focusrite Saffire 56 with PT 11?
It won't connect to the card, but using it in standalone mode, you can hook it up via Adat to your HD interface.
Old 07-24-2013, 01:43 PM
That's great to know.
do you have to use any kind of sync?
Glyph Raid 4
Old 07-24-2013, 02:04 PM
Raggi Raggi is offline
Using the LS56 with Win7 and PT-11 and it works great. I have 2x OctoPre mkII dynamic for 24 channels via adat and it works perfect just as in 10.
Old 07-24-2013, 04:43 PM
If you hook it up by Adat, you would set up the Saffire to be clocked via Adat. This is done in the included Mix Control software. Your HD interface clock would be set to internal. So basically the HD interface would be the master clock and the 56 would be clocked to it.
Old 07-25-2013, 04:44 AM
Great, thanks.
Glyph Raid 4
Old 07-28-2013, 09:59 AM
Well...I ordered one up.
I'll post how it works later.
I'm building a new small system.
Glyph Raid 4
Old 08-03-2013, 05:01 AM
Well...I got the focusrite liquid saffire 56 and hooked it up.
I have the ADAT out hooked to the digi 192 in and the mics are working great.
Now I want to monitor the mix out of pro tools. I'm having a little trouble here.
Do I hook the 192 ADAT out to the focusrite saffire ADAT in to monitor the mix?
Glyph Raid 4
Old 08-03-2013, 04:34 PM
I routed the output of the 192 ADAT to the saffire ADAT input.
Still no sound.
Any clues?
Glyph Raid 4
Old 08-03-2013, 05:11 PM
YYR123's Avatar
YYR123 YYR123 is offline
What are u using to monitor ur mix normally ? The 192 right ?
To monitor ADAT u would do that off the I/o settings - no need to route it back to the Saffire
Daniel
Focusrite Saffire Pro 14 with 10.3. Soundburst Pro Tools 10 5 10-10-2012 10:31 AM
PT9 with Focusrite Saffire 56 - with a Mac YYR123 macOS 2 02-23-2012 01:14 PM
Anyone using a Focusrite Saffire Pro 26 I/O ? Ru_C macOS 1 03-17-2011 09:51 PM
FOCUSRITE SAFFIRE??? CHEEZGRITS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-26-2005 04:12 PM
Focusrite Saffire Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-22-2005 08:23 AM
