Old 07-20-2013, 03:31 AM
CR92 CR92 is offline
Default Using Protools 10 AND 11
Hey Guys,
I'd like to get the new PT11 but I don't want to get rid of PT 10. Is PT11 only an "Update" or is it possible to keep both versions on my mac? Thanks!
Old 07-20-2013, 03:48 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Using Protools 10 AND 11
You get both when you upgrade.
Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
protools@verizon.net
Live and Let Live
Old 07-20-2013, 03:49 AM
musicman691 musicman691 is online now
Originally Posted by CR92 View Post
Hey Guys,
If you read the info on Avid's pages and here you'd know when you get PT11 you get a combo license that allows you to have both PT10 and PT11 on the same machine at the same time. You just can't run them both at the same time. PT11 is NOT an update as such but a whole new program.
Jack
QAPLA!
Old 07-27-2013, 03:11 PM
Thanks!
Old 07-27-2013, 03:37 PM
Oh yeah, 11 is new, in a HUGE way. You can install both 11 and 10.3.6(its gotta be 10.3.6). PT11 does not work with any RTAS plugins at all. The reason for the co-install is, so you can work in 10 with any current RTAS plugins. Give it about 3 more months or so for all the 3rd party plugins to get ported to the new AAX 64 bit format. Once that happens, 11 will be killer.
Old 07-27-2013, 05:56 PM
Niilo Nuori's Avatar
Niilo Nuori Niilo Nuori is offline
So how does it actually work? If you have a PT 10 session with lots of RTAS plugins and VIs and you try to use it in PT 11, does PT 11 just ignore those plugin that are not compatible (makes them inactive or something)? And if you have a PT 11 session with AAX64 plugins and take it back to PT 10, does it work there similarly? I am not sure how this "working with both 11 and 10" actually works because to me it sounds like you can work on PT 10 as you have been able to for months already and only when you have all your session plugins in AAX64 you can start using PT 11 (and I hope plugin settings etc. will follow).
If Avid had had the foresight to actually implement the many times requested proper track freeze (like the fantastic Samplitude), I could easily see working on PT 10, freezing those tracks that have plugins that are not available on PT 11 and then working on PT 11 on other tracks.
__________________________________________________ _______________________________________
Intel i7-2600K @ 3.40GHz + GigaByte Z68X-UD3H-B3 + Noctua NH U12P SE2 + 16GB + EVGA GTX 950 SC+
Windows 10 Professional x64 + 2 x Monitors + RME 800
StudioOne + Cubase for unlimited power, usability and features (+ Pro Tools for simpler old stuff)
Old 07-27-2013, 07:17 PM
CME CME is offline
It works basically like you said. If you start in 10 using RTAS plugs and then open in 11, the RTAS plugs are made inactive.
As far as I know any plugs that work in 11 also install a version that works with pt10. So you won't lose that going backwards.
But yes trying to find workarounds for using your must have RTAS plugs while staying mostly in 11 is a pita.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! G ray 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-12-2011 07:09 PM
Sending protools projects to other protools users online kdtufan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-24-2008 07:18 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
