Old 02-08-2010, 02:42 PM
huzzam huzzam is offline
Default Rendered Elastic Audio files disappearing!
Hi everyone--
I've been editing a session with Elastic Audio (polyphonic & rhythmic modes) on 8 tracks. I'm going to do the mixing on a PT HD 7.2 system, so I want to commit the Elastic Audio edits to regions.
So, I went to each track first & set it for Rendered processing (takes forever), and saved and quit. On reopening the session, PT complains that 87 rendered elastic audio files are missing. I tried both automatically & manually to relink them but they really do seem to not exist! Giving up, I let it "Automatically Re-create Missing Render Files without Searching". It finishes (takes forever), I save & quit & reopen, and they're missing *again*!!!
Have others run across this bug? Have you figured out a solution??? It would be a gigantic drag to lose all the rhythmic editing when we go to mix.
I'm on PT LE 8.0.3 (not cs1, not pr) on a Macbook core2duo/2gHz/3gb ram, Mbox 2 Pro, external firewire audio drive.
thanks
~peter in oakland
Old 02-08-2010, 02:44 PM
Default Re: Rendered Elastic Audio files disappearing!
ps-- I can, of course, bounce each track's to a new track, but this is supposed to work, so...
Old 02-08-2010, 06:09 PM
anyone?
Old 02-09-2010, 06:19 PM
MeBangKeys MeBangKeys is offline
It's happening to me, too.
I just loaded a session and a Bass track had mysteriously disappeared. It was there five minutes ago when I exited Pro Tools.
Old 02-10-2010, 07:55 PM
tom123 tom123 is offline
I have this same problem in several sessions and I am on deadline with a client. In one session I have six polyphonic elastictime regions missing and on another fifty or so which wiped out an entire bass track and bass drum track. THey were monophonic and rendered. The regenerate option does not bring them back.
I am using PTMP 8.0.3 with Windows XP home on a dell laptop PC.
This is a significant problem. Can digidesign weigh in here please?
Old 02-11-2010, 12:01 AM
tamasdragon tamasdragon is offline
Uh, it's nasty. Never had this one.
Have you tried any troubleshooting steps?
Obviously the trashing prefs&databases, plugin compatibility, etc.
my blog:Tamas Dragon
Old 03-02-2010, 03:41 AM
OliS OliS is offline
Hey all,
I'm seeing this as well on M-Powered PC, on versions 8.0.1 and 8.0.3.
Lost 98 rendered files twice yesterday. I checked the rendered folder for the appropriate session the second time, and nearly all the rendered audio files were deleted when I closed PT.
What's going on Digi?????
Old 03-03-2010, 05:18 AM
OK all, quick update....
I've just trashed Prefs and DB's with the Tech Support Tool and rendered a few files in one of my sessions. Still deleting the rendered files on PT exit.
Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!!
Oli
Old 03-03-2010, 06:02 AM
AdamPT8 AdamPT8 is offline
No backup?
Old 03-03-2010, 12:50 PM
I've got a backup of the session, but having watched the directory structure, PT is deleting the files on exit, other than a couple that I must have rendered some time back.
I'm surviving on Polyphonic for the moment, and bouncing down when rendered (which is a royal PITA)
I've sat and watched it render a few, create files in the session 'Rendered Audio' folder, saved the session, and then on exit, watched them be deleted again.
Missing Rendered Elastic Files Electric Peak Pro Tools 10 10 10-18-2019 10:37 AM
Have to manually clean up rendered files after committing elastic audio processing jdholman1 Pro Tools 9 1 05-30-2011 12:57 PM
Getting rid of excessive rendered files from elastic operations mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-08-2009 01:54 PM
delete rendered files elastic audio BUG!!! carlos santana Pro Tools TDM Systems (Mac) 39 12-26-2008 11:02 AM
Help me w/ rendered Elastic Audio, pleeze guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-25-2008 07:03 AM
