Old 01-15-2009, 08:59 PM
pguy pguy is offline
Default Other Samples with Structure?
I was watching the Structure video on the Digidesign website and Phil Jackson mentioned that he was using samples from Native Instruments in Structure.
Do all Native Instruments work in Structure?
Will they work in the "Structure Free" version?
What about samples from other companies like....
Sonic Reality Refill Samples
East West Samples... From "Colossus" etc,
Thanks.
Old 01-16-2009, 04:50 AM
barstool719 barstool719 is offline
Default Re: Other Samples with Structure?
I believe that you can do that with Structure LE. Structure Free is limited to the preset patches only, IIRC.
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64
Focusrite Saffire Pro 40 / Pro Tools 9.0.3
Mics, Guitars, Amps, Basses, Drums, Keys
http://overtheeffect.bandcamp.com
Old 01-16-2009, 05:53 AM
Holly73 Holly73 is offline
According to Digi's webpage even Structure Free can read Kontakt files: http://www.digidesign.com/index.cfm?...2&bprintonly=1
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 01-16-2009, 06:49 AM
right on. my bad.
you can import them, but you cant map them.
Old 01-16-2009, 08:05 AM
lwilliam lwilliam is offline
Thanks.
Refills are for Reason only. I don't think any sampler will import them.
Many of the EastWest collections (like Colussus, SD2, etc) are in the proprietary "Play" format as a VI and can't be imported into any other sampler. I think Digi has a couple of EastWest libs that have been formated specifically for Structure though.
There are lots of sample libraries that are in the Kontakt or EXS24 format that can be imported.
Larry
PTLE8/002r;OS 10.6.4 2 x 2.26Ghz quadcore,6GB RAM, Waves Platinum, many other plugins...
Old 01-16-2009, 08:19 AM
Thank You Guy's!
Could you please explain what it means to.....
"Map the Samples"
Old 01-16-2009, 09:22 AM
Thank You Guy's!
"Map the Samples"
you cant reassign the keys that play the sample.
Samples for Structure mmcl Virtual Instruments 3 06-05-2013 08:07 PM
Foley/FX Samples for Structure marc.seguin@cftpa.ca Post - Surround - Video 10 03-18-2009 02:19 PM
Looping samples in Structure LE. Blank Frank Virtual Instruments 1 02-26-2009 12:39 AM
Structure samples don't sustain TOM@METRO Virtual Instruments 6 12-28-2008 04:19 PM
Help Loading samples in Structure 14choirs Virtual Instruments 2 07-19-2007 05:31 AM
